gsr in ek
Old Apr 1, 2009 | 11:09 AM
PhrequenC's Avatar
Default gsr in ek
can someone give me a diagram of stuff to get a gsr into an ek? all the lines and stuff are a lot different than the LS which i took out just now. i just need to know where the vacuums go etc.
its a obd2 gsr.
i cant get the car to start either
there is water from the radiator coming out of the iacv??? through a drain plug and im starting to think the engine is donezo like rings or something i havent yet done a compression test. trynig to get my tools
Old Apr 1, 2009 | 12:07 PM
PhrequenC's Avatar
Default Re: gsr in ek
forgot a ground all fixed
Old Apr 3, 2009 | 09:23 PM
PhrequenC's Avatar
ok car shut off on me.. checked all my wiring and its there.. not getting spark
PhrequenC's Avatar
changed out the dizzy and still not workin just cranks
Old Apr 4, 2009 | 09:10 AM
PhrequenC's Avatar
getting spark but its WEAK with brand new dizzy
Old Apr 4, 2009 | 09:13 AM
EGhatch87's Avatar
what about fuel? if you have both might be timing...
Old Apr 4, 2009 | 09:15 AM
Hanmin's Avatar
is your ground on good? you need a few, the more the better=].
at least one on the transmission and one on the valvecover.
Old Apr 4, 2009 | 09:24 AM
PhrequenC's Avatar
yes, fuel and spark is there, compression is there.
i have 3 grounds, vc, trans, and tstat hosueing
Old Apr 4, 2009 | 10:46 AM
HarosGSRek's Avatar
hey man im in the process of doing the exact same swap right now. what wiring harness did you use?
Old Apr 4, 2009 | 11:08 AM
PhrequenC's Avatar
stock ex harness. extended some wires tho
Old Apr 4, 2009 | 11:09 AM
HarosGSRek's Avatar
what about for the dizzy? the ex harness has one plug and the gsr has 2 doesnt it?
Old Apr 4, 2009 | 11:11 AM
PhrequenC's Avatar
no i modified the dizzy plug by unplugging all the wires from my harness and using a pigtail from another harness to make it nicey nice. btw my engine is obd2 not obd1 which has 2 plugs
Old Apr 5, 2009 | 11:58 AM
PhrequenC's Avatar
honestly dont even know where to diagnose the car. i second checked everything.. and from what i know, its geting fuel spark and compression.
Old Apr 5, 2009 | 08:10 PM
Hanmin's Avatar
obd1 gsr dizzy has 2, the obd2 one has one big plug. check spark plug gap???? it should run. stumped
Old Apr 6, 2009 | 03:50 AM
PhrequenC's Avatar
timing skipped. intake cam jumpd 180*.. all fixed now tho
LittleT147
Engine Machining & Assembly
Oct 29, 2018 08:48 AM
tigmandick
19
May 21, 2010 10:13 PM
banginek96
Apr 27, 2010 06:09 AM
integrator43
Feb 24, 2005 06:10 PM
LukeDanger
Dec 28, 2003 05:15 AM
