help
i have a question..i have a 93 del sol s..5 speed..and when i put it in gear and step on the gas it doesn't give much power..like it revs high..but the clutch doesn't pop out..so it can't be my trans..could it be that i need to replace my clutch?..cause it takes a while till it actually grabs..lmk..help?
Sounds like your clutch is slipping to me. Probably have a bad clutch. By the way, when you make a topic, make your title more specific to what you are asking instead of just "help." That way when other people search for a similar issue they can find the topic. Just a word of advice.
Revs high clutch doesnt pop out ? Explain more please? If it revs and doesnt move or moves slowly the clutch could be bad. If the clutch doesnt engage completely then it could be in master or slave cyl, throw out bearing, other things that control the clutch.
Street Racer X
Sep 21, 2008 02:35 PM
