HELP! Headgasket replacement
everything is unplugged, dizzy, vtec solenoid, coolant is drained, and valve cover and cam covers are off, i set it to cyl 1TDC. Do i need to pull my cams to get the head off?
nvm, found a post with it. i just dont want to have to deal with all the timing bullshit. do i need to use a sealant when i put the new gasket down? or just clean the surface and i should be good
You can use copper sealant to ensure it will seal. Make sure to clean the head and the block of any old gasket material if there is any on there. Also if your car has overheated in the past, make sure to get a straight edge and a set of feeler gauges and make sure the block and the head are within spec so you dont put it all back together and still have a blown headgasket because something is warped because of overheating or improperly taking off the head bolts.
i know the bolt sequence for the b16 head. i know the torque specs, but for my life i cant get these bolts to come off, even with a 18 inch breaker bar.....im using a 14 mm socket, and it stripped on the bolt....any ideas? i hate cheap tools. What size socket should i be using on the head bolts?
as far as getting the head checked for warpage....how can i do that
