power folding mirror help
Old Mar 31, 2009 | 09:29 PM
exotik4doorcivic's Avatar
Default power folding mirror help
anyone know if you can swap everything from a power folding mirror into a usdm mirror
and anyone have a diy for installing these, on a 1993 civic,
i have the mirrors switch and relay
any help is appreciated thanks
Old Mar 31, 2009 | 09:58 PM
crx_si-r's Avatar
Default Re: power folding mirror help
you want a harness? if so pm me i just installed some on my crx. and made my own harness. lmk
Old Apr 1, 2009 | 08:09 AM
the car origionally has power mirrors but i need to add the power folding wires
i think its just 2 wires but i cant find anything for installing them
Old Apr 7, 2009 | 09:06 PM
crx_si-r's Avatar
its not as easy as just tapping in the 2 wires for the folding option. you need to have the 95U i believe is what its called relay which allows the mirrors to fold with the switch when the button is pressed.
Old Apr 7, 2009 | 09:40 PM
pdotjones's Avatar
you wont be able to swap parts from mirror to mirror.. i tried... its not easy to install them, but its not terribly(sp?) hard with a little patience. to do a clean *** job, you'd have to run the wires through the existing door harness, meaning pinning the harness which can be a bee-itch! here is a diagram for an ek install, but the wiring is pretty much the same..... https://honda-tech.com/forums/audio-security-video-27/d-relays-try-wire-up-these-mirrirs-all-wiring-diagramswiring-up-ctr-mirrors-1847948/ i hope this helps you out...
Old May 15, 2009 | 11:54 AM
egpatrong's Avatar
Originally Posted by pdotjones
you wont be able to swap parts from mirror to mirror.. i tried... its not easy to install them, but its not terribly(sp?) hard with a little patience. to do a clean *** job, you'd have to run the wires through the existing door harness, meaning pinning the harness which can be a bee-itch! here is a diagram for an ek install, but the wiring is pretty much the same..... https://honda-tech.com/forums/showthread.php?t=1847948 i hope this helps you out...
thanks mate ...this is wat i need...
ek_four
Oct 4, 2009 05:51 AM
doubleoazn03
Jan 17, 2008 10:23 AM
BillyBalls
Jul 18, 2007 06:30 PM
PrOjEct CTR
Jul 27, 2003 10:25 PM
PrOjEct CTR
Jan 3, 2003 09:40 PM
