!!!**(Desperate!) Need Fuel pump help**!!!
Hey guys, i have a HUGEE issue with my fuel pump, any thoughts on how to fix it would be so much help at this point...
Ok, so heres the deal. I installed a new fuel pump today, after the installation i tried to prime the pump. The pump did not prime. 1st thing i thought is bad connection or ground Right?! No. It had all good connections, so i checked all of the fuses inside and outside of the car along with the relays.. Even checked for Omes though them with my volt meter...Nothing, zero, all of the fuses and relays were good..
My next step was to see if my harness had power going to it, I got no volts going to the harness, before OR after the plug end where it goes into the pump...
My 3rd step was to wire the pump to a GOOD source of power to be sure that the pump actually did work. I hooked the pump to turn on with my headlights...I turned my headlights on and GOOD. The pump turned on just as it should but now the car still will not start... Great.
SO, my question is what is ...am i missing a fuse or relay that is hard to find that im not seeing? How did my harness get totally ****ed if the car ran perfectly fine b4 i put the new pump in?!? What is going wrongg!>!??!?! ANY help would be great ASAP It just seems as if something is not allowing the power to travel thru my harness. Aghh
Thanks, Mike
Thanks, Mike
No i checked it, and i even took my volt meter adn tryed it before the connector end, and still no volts..agh its driving me crazyyy
Edit: I just found this thread and iv tryed almost everything...https://honda-tech.com/forums/showthread.php?p=36428356
Fuel pump relay, haven't done the one on an integra yet but on an accord and civic, its brown and either above the driver side kick panel (civic) or further up under the dash (accord). Plus you should hear it click anyways.
damn that sucks... haha i had wiring issue in my teggie
i did a clutch swap myself and didnt realize i left my 02 sensor wire resting on my exhaust i got about 3/4 mile from my house and pop pop the wire melted and fused to the exhaust creating a short that burned up my ecu fuse line
... im in the process of replacing my main harness now
Lsv4free
Sep 1, 2014 06:13 PM
ill phil
Apr 23, 2003 11:58 PM
