K24 question (noob)
Old Mar 31, 2009 | 08:01 PM
g0tgot's Avatar
Default K24 question (noob)
new to the k series, from my understanding what would I benefit from having a K24 with K20R cams? would this be an ideal swap for an eg?
Old Mar 31, 2009 | 09:05 PM
Type-Spaz's Avatar
DC5/EP3 MOD :)
Default Re: K24 question (noob)
depends on which k24 you have and what head you're using
Old Apr 1, 2009 | 06:06 AM
g0tgot's Avatar
K24 was pulled from tsx, has pink slip. ill check the stamp later, is this generally the same idea as the b series? k24= the new B20 and K20= new B18C?
Old Apr 1, 2009 | 07:25 AM
josh's ep3's Avatar
Function > Form
Not quite the idea ^^ The one you want is a k24a2 which it sounds like that's what you got, if in fact it is the original motor out of the TSX. As for your analogy, I wouldn't even compare a K-series motor to a B-series. K-series FTW!!
Old Apr 1, 2009 | 08:31 AM
Type-Spaz's Avatar
DC5/EP3 MOD :)
I have a straight k24a2 swap in my rsx. No head swap just the full engine.
Old Apr 1, 2009 | 01:12 PM
dan12288's Avatar
how much did it cost to get it all running?
Old Apr 1, 2009 | 01:31 PM
g0tgot's Avatar
what is the difference in performance>? is the k24 like an economy version>? or is it more beefy than the k20? i know liter wise its bigger, but that doesnt always mean that its better.
Old Apr 1, 2009 | 01:44 PM
blackk20dc5's Avatar
http://k20a.org/forum/showthread.php?t=23830
scroll down and read that thread there is a good post about what the k20 motor gives your and the k24 gives you and why they are great when put together.
Old Apr 6, 2009 | 08:42 PM
d16_2_k20's Avatar
k24=2.2L @200hp k20a=2.0L @220(or so)hp k20a2=2.0L @200hp
so a good combo would be k24 from tsx, with rsx type-s head with dc5R cams(valve springs)
seen this in an eg with a kpro as well, speechless..................
Old Apr 6, 2009 | 09:10 PM
DaveSi677's Avatar
wrong k24 is a 2.4 liter... also no mention of torque???
Old Apr 6, 2009 | 09:48 PM
PlayForFun's Avatar
Sorry to Hijack, but what about the new K24Z3 in the 08 accord.
I know a head swap was possible with the old k24a's but is the head assembly different on the z's? or is there even a point to a head swap with the eco friendly engine?
Old Apr 6, 2009 | 09:57 PM
connor53's Avatar
the new found torque in spaz's tsx engine is AMAZING!! btw.
Old Apr 7, 2009 | 12:33 AM
i drive a honda's Avatar
NO, K24 = 2.4l WHAT DO YOU THINK THE 24 MEANS?
hondata's kpro is the standaard, most people run it.
Old Apr 7, 2009 | 05:55 AM
mustclime's Avatar
different pistions.....it will not work with out a pistion swap.
Old Apr 17, 2009 | 05:41 PM
d16_2_k20's Avatar
lolz my bad, i had the mugen civic on my mind, (2.2) k24 is 2.4L
Old Apr 17, 2009 | 08:33 PM
SLEEPINDC5's Avatar
K20 ftw
garciamanuelzb
Jul 1, 2013 05:01 PM
shelltodreamda9
Jun 6, 2011 11:03 AM
joel92eg
Oct 5, 2004 05:03 PM
helzbelz101
10
May 6, 2004 05:59 AM
Samsonite
Nov 4, 2002 05:24 AM
