Clutch not engaging... Need Help
Old Mar 31, 2009 | 07:39 PM
ckinne's Avatar
Default Clutch not engaging... Need Help
So i dont know what else to do. I have replaced the slave and master cylinder, properly bleed the lines so there is no air in the system, and I still cant go into any gear. The only gear that it will remotely let me get into is reverse and it grinds. By the way, its a b18c1. Let me know what you guys think.
Old Mar 31, 2009 | 07:42 PM
JohnnyWash1's Avatar
Default Re: Clutch not engaging... Need Help
Are you sure you bled them throroughly? Do you have pedal pressure?
Old Mar 31, 2009 | 07:46 PM
Former User's Avatar
Is the shift fork that contacts the slave cylinder broken?
Have you tried adjusting the clutch pedal?
Old Mar 31, 2009 | 08:12 PM
ckinne's Avatar
The line was bled properly. i re-adjusted the clutch pedal after installing the new master cylinder. I'm not sure about the shift fork though. I am going to pull the transmission tomorrow and check it out but if the pressure plate or flywheel is not loose and the shift fork is not bent then I am going to be stumped.
Old Apr 1, 2009 | 05:50 AM
jdmboy96's Avatar
****in b-series tranny's lol
Old Apr 1, 2009 | 09:26 AM
kpaton's Avatar
Was everything peachy before you installed a new master?
Old Apr 1, 2009 | 09:53 AM
BDeckerB16A's Avatar
Check Master cyl, Get air out of the lines, check fork and make sure all bolts are tight. Check shift link and bolts. Was everything ok before ?
kizzkizz10
Dec 9, 2011 10:18 AM
1badcrx
Nov 28, 2011 08:49 AM
jdm_phunk
Feb 27, 2011 05:17 PM
PearlBlueType-S
20
Mar 6, 2006 11:10 PM
allmotorls95
Feb 26, 2003 01:30 PM
