Oil Light
Old Mar 31, 2009 | 10:39 AM
Retribution's Avatar
Default Oil Light
My cousin has an old 91 Accord that was purchased used as his first car about a couple of months ago. Couldn't help but notice that at times when sitting at idle, the oil light would come on and flicker. Checked the oil in the engine and found it to be clean and at the proper level. The thing that popped up in my mind is maybe the oil pump is getting ready to die, but not quite sure. Just wondering if anybody can give some advice. Thanks.
Old Mar 31, 2009 | 01:26 PM
ap716's Avatar
Default Re: Oil Light
might be oil pressure sensor/switch
Old Mar 31, 2009 | 03:11 PM
dtapia's Avatar
time to manually check the oil pressure with a gauge and see whats it at.
Old Mar 31, 2009 | 06:31 PM
DrZFiNeSt's Avatar
Sounds like you have a bad oil pressure sensor
Old Mar 31, 2009 | 07:32 PM
H22_aCCoRd_07's Avatar
if you have an extra oil pressure switch laying around try and see if that works if not check oil pressure, if oil pressure is low, FIRST make sure your oil pan isnt dented up. If it isnt its probally the oil pump
Old Apr 1, 2009 | 05:04 PM
Thanks guys, I'll try checking the oil pressure first.
Old Apr 1, 2009 | 05:10 PM
90sedan's Avatar
Actually, 9/10 times when the oil pressure light flicks on and off at idle its due to worn bearings.
That other 1/10 may be the oil pressure sending unit, it is almost never the oil pump.
Old Apr 1, 2009 | 06:22 PM
Well, the engine does have almost 200,000 miles on it. I wouldn't doubt it.
TORTUGA
Oct 28, 2013 11:32 AM
lonewsome
Jan 1, 2009 01:42 PM
eric416
Oct 9, 2008 04:03 PM
shrirag
Apr 11, 2007 09:55 AM
BACKintheDA
Jul 12, 2005 01:05 PM
