Rear disk on EK
Old Mar 31, 2009 | 09:55 AM
92'si's Avatar
Default Rear disk on EK
Do you need to put an Si Master Cylinder, Prop Valve, and Brake Booster on when you are swapping an EK's drums for Disk?
Thanks in advance.
Old Mar 31, 2009 | 10:06 AM
GetawayInMoscow's Avatar
Default Re: Rear disk on EK
You only need the master cylinder. If you have an EX you need the proportioning valve too, if you have DX, CX, HX, or LX it's already the same prop valve as an SI.
Old Mar 31, 2009 | 10:23 AM
NightCat's Avatar
bah...damn EX...Im throwin some GSR disks in the back of mine so I feel ya.
Dont gotta redo any of the plumbing? just change out the prop valve?
and btw, wont an Integra master cylinder work too?
Old Mar 31, 2009 | 10:30 AM
BlitzSix's Avatar
I don't think you need a master cylinder and brake booster..
Old Mar 31, 2009 | 10:31 AM
I think so, but almost all Integras came with ABS, where as no SI's did.
Old Mar 31, 2009 | 12:30 PM
Groovinator's Avatar
I don't think you are correct in your proportioning valves;
SiR/SI/EX model 46210-S04-852
Other models 46210-S04-902/901
Old Mar 31, 2009 | 12:59 PM
The EX has a different proportioning valve because it has bigger front brakes than the other models, but still has drums in the rear.
Old Mar 31, 2009 | 01:10 PM
NOFX's Avatar
H-T White Ops
This is what I got (I only did the year 2000):
VALVE ASSY., PROPORTIONING
46210-S04-822
00 4DR GX (ABS)
46210-S04-852
00 2DR EX ABS
00 4DR EX (ABS)
46210-S04-902
00 2DR DX
00 2DR HX*
00 2DR Si
00 3DR CX
00 3DR DX
46210-S04-912
00 4DR DX
00 4DR DX-V
00 4DR LX
46210-S04-922
00 4DR GX
46210-S04-962
00 2DR EX
00 2DR HX*
* = Uses multiple part numbers.
Old Mar 31, 2009 | 01:52 PM
EL Vap133's Avatar
You are talking Canadian part numbers there.
Old Mar 31, 2009 | 02:14 PM
not a difference canadian or not, the fact is they are different valves.
I was just trying to clarify things, I've always put in Si/Sir valves for all the swaps we've done as that's the only civic with rear discs up here.
Old Mar 31, 2009 | 03:06 PM
EL Vap133's Avatar
Well here in the US the USDM Si uses the same prop valve as the DX, LX, CX, etc. The USDM Si brake booster is also the same as the DX for sure.
Old Mar 31, 2009 | 03:14 PM
NightCat's Avatar
Someone told me that you can use the EX valve or some part of the EX for dear disks
Old Mar 31, 2009 | 03:33 PM
EL Vap133's Avatar
How so, the EX did not come with rear disc brakes?
Old Mar 31, 2009 | 03:35 PM
NightCat's Avatar
I dunno...I was talkin to some guy at a local junk yard and he had disks on an EJ1 and said somethin about "well if you have an EX.."I dunno wtf the dude said..just wonderin if anyone knows. there's somethin about the EX that makes it better to disk swap in.
skill178
16
Oct 9, 2011 04:38 PM
herde1724
Aug 11, 2005 11:37 AM
jdm92accord
Jan 31, 2002 08:15 AM
