Cluster problem
Old Mar 30, 2009 | 10:16 PM
StoCKcB7's Avatar
From: under the bridge cause im a worthless piece of shit!
Default Cluster problem
My Rpm work's but my mph dosent. when driving on the freeway, or going 50mph it jump's to 120-140. I have pull out the cluster and to check if all the wire's are plug in or loose and still dosent work. And i have check the wire that's plug into the tranny. Still dont work? anyone have any idea?.Do i need to buy another cluster? Or buy the whole gear thingy that plug's into the tranny?
Old Mar 30, 2009 | 10:41 PM
R666_EK's Avatar
Default Re: Cluster problem
If you have access to either another cluster or a VSS (the thingy that plugs into the tranny) try using it on your car. Someone correct me if i'm wrong, but I believe the VSS would throw a code if that was the case. Its probably just the Speedometer. What is your year/model? I have an extra EK DX cluster for parts.
Old Mar 30, 2009 | 10:44 PM
twiztid_989's Avatar
ur right it would throw a cel i have tha same problem w my eh9 and my temp gauge doesnt work either how to fix that i i've change tha cluster out and everything else to get it to work
Old Mar 31, 2009 | 08:56 PM
StoCKcB7's Avatar
Yeah my mph and Temp. doesnt work. But i guess ill just get a new cluster to see how that work's out.
StoCKcB7's Avatar
I have a 93 si with ls motor.
Old Mar 31, 2009 | 09:10 PM
R666_EK's Avatar
Yeah that's probably all it is. I had problems with my tach in my 99-00 si cluster and I replaced the tach assembly and voila! problem fixed.
Old Apr 1, 2009 | 11:37 AM
fireblaze2k1's Avatar
Yeah just change over your speedo. I bought an EX cluster for my egg and the speedo didn't work, I used the original speedo from the dx cluster in the ex and haven't had a problem yet.
VSM_EJ8_408
Mar 28, 2008 09:21 AM
turbo Si
Jul 9, 2006 07:12 PM
bubbakrip
Mar 29, 2006 09:37 PM
neXus dc4
May 7, 2004 07:17 AM
carlos
10
Oct 15, 2002 08:57 PM
