Door panel inserts? I need help!
Old Mar 30, 2009 | 09:23 PM
EFinawesomeman's Avatar
Default Door panel inserts? I need help!
I tried searching but this search engine just isnt what it used to be and could only find one thread but the gentleman's door panels were different from mine.
My car is a 97 DX and I can't figure out how you guys are doing your door panel inserts.
If you can point me to the thread that explains it thatd be great. Or tell me here.
This is where I am at.
Old Mar 30, 2009 | 09:56 PM
JHP's Avatar
JHP
Default Re: Door panel inserts? I need help!
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-diy-custom-interior-project-%2A%2Ano56k%2A%2A-2500737/
halfway through the page the guy does his panels over.
Old Mar 30, 2009 | 10:00 PM
Unseen Racer's Avatar
Originally Posted by JHP
https://honda-tech.com/forums/showthread.php?t=2500737
HAHAHAHA!
i was going to post that same one since i have it opened in another tab!
beat me to it
Haha yeah thats the one I found. I just now figured it out and got the fabric off. My panels are different from his though.
Old Mar 30, 2009 | 10:09 PM
is your car a coupe, sedan or hatch?
cuz i know that the sedan and coupe have different pannels. not sure about the hb.
yours look like a sedan panel
Old Mar 30, 2009 | 10:27 PM
JHP's Avatar
JHP
the panles look different but they seem to be attached the same way.
Old Mar 30, 2009 | 10:28 PM
Yeah its a sedan. I just poked through a couple of those holes and got the fabric loose. It's going to be tricky to get the edges. Might have to hot glue them.
Old Mar 30, 2009 | 10:32 PM
JHP's Avatar
JHP
are you using spray adhesive?
Old Mar 30, 2009 | 10:34 PM
Yeah for the backing atleast. Maybe not for the edges.
Old Mar 30, 2009 | 10:38 PM
JHP's Avatar
JHP
well its hard to tell but it seems that when you put it back together the panel itself will cover up most of the major imperfections. unless you really do a bad job...
Old Mar 30, 2009 | 10:43 PM
I've done it to all of my EF's. It will work fine. Plus the handle will be covering some of it too.
Old Mar 31, 2009 | 07:21 AM
HA! i knew it! but your pannels look different cuz you have a sedan and he has a coupe.
since the sedan has 4 doors, the door and pannels will be smaller.
when i did mine(which i still need to redo with real tweed) i hot glued the sides.
came out sexier than i imagined
Old Mar 31, 2009 | 08:03 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
can you give a close up picture of the connection points on the panel??? i cant tell from that picture posted...
Old Mar 31, 2009 | 05:02 PM
There are no connection points. It is just spray glued on the back and hot glued where all the little holes are.
The G2 Racer
Feb 9, 2009 09:06 AM
06siracer
Honda Civic (2006 - 2015)
Jan 21, 2008 04:28 PM
Solo2Vtec
Jan 30, 2007 10:56 PM
Honda_Accord
Jun 11, 2006 05:44 AM
BigZ88
Jun 21, 2003 03:55 PM
