PLZ HELP..................camshaft rubber plug
Old Mar 30, 2009 | 05:58 PM
danielblushtein's Avatar
Default PLZ HELP..................camshaft rubber plug
hey i got a 95 gsr and I wanted to change ou the camshaft plug that is on the right side near the vtec cylinoid. I believe it on the exhaust camshaft side.
I just want to know if I need to take off the camshaft long thing that holds the camshaft down. If I do(which I think I do) then is there a certain torque spech for those bolts?
Also do I need to do anything with the timing belt or will the camshaft move or anything.
P.S. Is it hard to change out the dizzy O ring?
THANKS GUYS!!!
Old Mar 30, 2009 | 10:03 PM
Default Re: PLZ HELP..................camshaft rubber plug
anyone do it?????
Old Mar 30, 2009 | 10:07 PM
JDM 98 GSR's Avatar
no you dont have to touch the cam or timing and they should be torqued. buy a helms manual
Old Mar 31, 2009 | 10:43 AM
HeikDiesel's Avatar
Have oil leaking down the passenger side front of the engine block? It's more than likely your exhaust cam seal. This is known to be a culprit for a lot of leaks and a lot of aftermarket companies make replacements that utilize o-rings for a more effective seal. This is pretty simple and easy so save yourself a few bucks and do it yourself.
First pop your hood and this is what you should see. See how the front of my block is all nasty and covered in oil. We are going to fix that!
Next remove all spark plug wires and the nuts circled in blue. They are a 10mm head. After the nuts are removed there will still be a washer stuck to the valve cover. Use a screwdriver or needle nose pliers to pull them off. You don't need to keep track of the order of the wires. The length is pretty self explanatory on install. Torque specs for the valve cover nuts are 7.2lb/ft in numeric sequence
Next remove the breather line from the valve cover. You might need needle nose pliers to remove a clamp that holds this line onto some valve covers
Now the valve cover is ready to come off, just wiggle it a little bit and it should pop right off. Then you should see this. Remove the bolts circled in blue to remove the oil rail
After the oil rail is off, simply remove the very last cam cap. If you are looking at the engine is on the exhaust side on your left hand side. Remove the two bolts that hold it. You don't need to remove the stud. After the bolts are out, pry with a flat screwdriver against the head VERY LIGHTLY where the red arrow is to separate the cap from dowels in the head. It doesn't take much so be gentle. Torque specs for bolts 1-10 is 20lb/ft and 11-14 are 7.2 lb/ft
Underneath it is the cam seal. My car happens to have a golden eagle aftermarket seal and as you can see the o-rings have seen better days. I took it to a local carquest autoparts store and found replacements. I'd suggest an aftermarket one if you are going to tear into it this far. They are much better than the OEM ones in this case
Install is just the opposite of removal. Install the cam seal, put the cam cap and the two bolts back in. Torque those two bolts. Install the oil rail and bolts. Torque those bolts. Clean off the mating surface of the cylinder head and Honda suggests to use a new valve cover gasket but as long as the seal is soft I usually reuse them. Never had any issues. Honda also suggests to apply HondaBond to the four corners of the head shown in this pic to help against leaks.
Install the washers and nuts for the valve cover. The longer studded nuts go in the middle for your spark plug cover. Install your breather line and you are done. Remember to ALWAYS torque internal bolts. You might get away with hand tightening some bolts but I've seen tons of these bolts snapped so take the extra time and torque them. If you guys want any other tech articles just let me know I'll do my best to do some for you. Thanks
-Kris
Copyright 2008 IpbRacing Productions
Old Mar 31, 2009 | 10:44 AM
HeikDiesel's Avatar
quoted from a tech article I did awhile back. Enjoy
Old Mar 31, 2009 | 02:14 PM
DANG DUDE THANKS!!!!!
but the camshaft will not move out of place or anything??
Old Mar 31, 2009 | 03:34 PM
HeikDiesel's Avatar
Nope
Old Mar 31, 2009 | 05:13 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
The aftermarket plugs are not necessary. Honda redesigned the plug in the mid-90's from a solid rubber plug to a plastic plug with o-rings. I installed the redesigned plastic plug on my car back around 2002 with about 115K on the car. Now I'm at 276K miles and have had no leaks whatsoever from that location.
Old Mar 31, 2009 | 10:38 PM
aldaman's Avatar
New User
Great write up & illustrations...Thanks...
Old Mar 31, 2009 | 11:47 PM
igorka_91's Avatar
THANKS GUYS!!!
ey hahol kagda mi eto bydem menati na twayey tachke........ dawaii zavtra ili v chetverg..?
Old Apr 1, 2009 | 07:14 AM
twentyhurtz's Avatar
nice write up, i was thinking about changing mine and using a skunk2 plug
Old Apr 1, 2009 | 07:57 AM
totsie7944's Avatar
You guys could just honda bond around the outside of the plug, make it look neat, and not have to go through the hassle of pulling the plug out or taking the valve cover off, etc...however if you go through all that, just run some honda bond around that plug before re-installing. I've never had a leak doing it this way with about 40,000 miles on a very high performance motor now making 600 hp
Old Apr 1, 2009 | 09:55 AM
rebar71's Avatar
I tried that once with mine. It didn't work.
I can't believe you would skimp on a $10 part with 600 hp motor. It only takes 30 minutes to change out.
Old Apr 1, 2009 | 11:08 AM
totsie7944's Avatar
You probably didn't do it adequately or allow enough dry time before heating up the motor. I have built and rebuilt motors more times than I can count now. There is no need to replace the cam plug each time you take the head apart. If its in good condition just pull it out, run some honda bond around it, and then torque everything back down properly. I've never once had a leak and even if I got a brand new plug I'd still use honda-bond for a sure seal.
Old May 31, 2009 | 08:42 PM
midnighteg-6's Avatar
-Kris
not to go out of the conversation but wath type of cam is that i noticed the grooves on it is it a type r cam what year of type r
Old May 31, 2009 | 08:59 PM
follie gatts's Avatar
i am surprised that the replacement failed as well. is your car boosted or something?
just wondering. i have a golden eagle plug sitting here in the house waiting to be put in.
CKnight90
Dec 2, 2013 11:00 PM
ADerks12
Jul 29, 2008 06:56 AM
4crx4me
Jan 7, 2006 02:39 PM
pancake
Feb 10, 2005 01:50 PM
Specialk
Jan 14, 2003 07:50 AM
