Burnt valve replacement
Old Mar 30, 2009 | 12:57 PM
sde780's Avatar
Default Burnt valve replacement
I found a d15b2 for $90, but the seller says one of the cylinders is dead due to a burnt valve.
1. How hard is it to replace? I looked in the service manual but it doesn't tell you how, only how to remove the head.
2. Do I need any special tools to do this job?
Old Mar 30, 2009 | 02:25 PM
iwanttokillgod's Avatar
Default Re: Burnt valve replacement
if you have to ask then its over your head
Old Mar 30, 2009 | 03:07 PM
4drEF's Avatar
Keyboard Humorist
Which service manual are you using?
Have to remove the head, remove the valve and then inspect to figure out WHY the valve burned in the first place. Fix whatever caused the valve the burn, lap the new valve, install valve, replace head, and set lash.
Old Mar 30, 2009 | 03:36 PM
sde780's Avatar
Sounds like I'd need to know what I'm doing. Scratch that idea then, thanks for the clarification.
I'm using a service manual I downloaded off somewhere
maxogsr
Mar 20, 2010 04:17 PM
seelyd
Dec 27, 2006 03:06 AM
Red D Dragon
May 5, 2005 10:16 AM
dizzyroc88
Jan 18, 2004 09:45 AM
fe519
Dec 27, 2002 12:50 PM
