Tranny Broke today???!!
Old Mar 30, 2009 | 12:17 PM
91EF919's Avatar
Default Tranny Broke today???!!
Ok well i was leaving my neighborhood waiting for the gate to open, and when it opens i put it in first and i start to move but i hear a big thump, and its not in a gear, so i try to take it out of first but its jammed into there. So i turn off the car, and i force it out of first so i can put it in N so i can move the car so i do that and move it and i pop my hood to see what happened, so i go back in my car start the car and i can barley move the shifter i got to force it into gear and i do that and see if the car moves, but nothing it just sits there trying to go it act likes the e-brake is up and ur trying to go. So i try second i force it and same as first but then i hear another big thump and now the shifter is all loose and easy to put in gear but no gears work. And i look under my car and see oil leaking and its coming from the tranny. So i wanted to know what caused this and that this means my tranny is toasted.
Old Mar 30, 2009 | 12:20 PM
dr_latino999's Avatar
Default Re: Tranny Broke today???!!
If you want to know exactly what caused it, put the car on stands and get to work dissecting the transmission.
Old Mar 30, 2009 | 01:40 PM
ef-hatchcrap's Avatar
Sounds like a bad bearing that broke the case I have had it happen to me with a single cam ytranny before
Old Mar 30, 2009 | 01:53 PM
DCFerris's Avatar
ef-hatchcrap is right sounds like the bearing went and that usually means the tranny's gone but your gonna have to take it apart to see what damage is done
Old Mar 30, 2009 | 05:53 PM
91EF919's Avatar
i am thinking get a used one, or rebuilding it but it cost a lot to rebuild. I think my gears are bad anyways cuz like 3 n 4 grinded after it all happened, but when it was leaking the oil i didn't see no metal shavings or nothing it looked brand new.
Old Mar 30, 2009 | 06:04 PM
Hmmph. I'll begin at the beginning.
- "I'm thinking about purchasing a used one." Why, so the same issue can pop up again? Why chance the same fault when you can preemptively remove the problem through a rebuild of the current unit or a rebuild of the used unit.
- "I think my gears are faulty due to grinding during engagement." Those are a function of synchronizers, not the gears themselves unless the gears are destroyed.
- "The oil appeared brand new." Here's the thing, if you open up your transmission you will find two magnets probably covered to the brim in metal shavings, working transmission or not. Those little buggers do their jobs quite well.
Old Mar 31, 2009 | 10:33 AM
91EF919's Avatar
ok thanks for the advice, i just dont have the money to rebuld it.
Old Mar 31, 2009 | 10:39 AM
steveo135's Avatar
well guess you just made your decision... start looking for your used tranny..
/thread
Old Apr 5, 2009 | 10:50 PM
91EF919's Avatar
Well i wanted to check something today to see if my differential was broken in my tranny, so i put the car in 1st and try to spin the wheels and they still spin, so i put it in reverse and still spins so i have a bad differential, so are my internals bad or just the differential? I have another casing so i will swap gears, and get some syncros, and probably a lsd for better traction.
Old Apr 6, 2009 | 07:22 AM
Just take it apart and find out exactly went wrong
Old Apr 6, 2009 | 07:36 AM
shaggyeg6si's Avatar
You can't identify this type of problem without actually dissecting the trans. There is a good link for it in the FAQ's, I think it's Ben Ogle's site.
Old Apr 6, 2009 | 07:40 AM
SOHCinWA's Avatar
I have seen clutch discs break apart.. You really need to pull the trans and see what it is....
Old Apr 6, 2009 | 08:11 AM
efjones9's Avatar
sorry for jacking your thread. but how do you know exactly when ur tranny needs a rebulid or its completely gone?
Old Apr 7, 2009 | 11:18 AM
benwadb1's Avatar
I have this happen as well, the gear oil leaking is a bad sign, probably not anything to do with the clutch.
In my case I blew the pinion shaft and pinoin gears out into the street, and the speed sensor drive out the top of the case, the the case around the gear selector rod popped and was touching the street hanging on by the bushing.
So yes I had to get another case and diff, frankenstein a used tranny to make one, the used tranny was crap 2nd,3rd,and 4th synchros were worse than my originals, replaced the seals and two bearings.
Rheg6
Transmission & Drivetrain
Nov 23, 2011 11:13 AM
DriveSlowHomie
Apr 16, 2008 03:25 PM
b18b1hatch1
10
Jan 14, 2006 11:39 AM
dntbh8n
Aug 7, 2005 01:09 AM
