ITR swap into EJ6
Old Mar 30, 2009 | 12:01 PM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
Default ITR swap into EJ6
So my buddy is going to sell me his JDM ITR for ridiculously cheap, pending that i take the motor out of his hatch and swap my built B16 into it. I currently have the B16 in my EJ6 ('96 DX)...what my question is, will i have to switch over all of my wiring harnesses and what not to install the ITR into my EJ and the B16 into his hatch?? Also, my B16 has no P/S or A/C, and im going to take those off of the ITR as well. Can i simply unbolt them, remove all lines and belts and be done? im thinking not...Im running a chipped P28 on my B16 and im thinking about running it on the ITR...im going to be switching my AEM fuel rail, and RC310 injectors over from my B16 to the ITR also. Any help would be GREATLY appreciated...I would like to know some things to look out for or be aware of before i get hung up on any of those things...TIA for all your help HT community...
Dc2
Old Mar 30, 2009 | 03:39 PM
Default Re: ITR swap into EJ6
nobody has any info??
funny how if you bought a new car or got it stolen or have a catchy headline, you get rediculous amounts of responses....
but if you have a serious tech question that you need answered in most times a timely manner....it doesnt happen....
Old Mar 30, 2009 | 03:44 PM
dumpsterbaby's Avatar
need more info, your car is 96-98 hatch? what year is his car? if you guys have the same obd systems then it should be a straight swap i believe
Old Mar 30, 2009 | 03:49 PM
my car is a EJ6 as its listed...'96 Civic DX Coupe
he has a 96-98 hatch....
hes running the JDM OBDII ECU and im running a OBDII to OBDI conversion harness for the P28....but i should be able to just plug my conversion harness into his main wiring harness of the ITR when i do the swap correct?
Old Mar 30, 2009 | 05:32 PM
yea so you both have your b series in a 96-98 civic, then everything you have is obd2a so yes this should all be a direct swap
Old Mar 30, 2009 | 06:59 PM
what about the power steering and the a/c??? do i just remove them and tap off the lines??
Old Mar 31, 2009 | 07:53 AM
bump for some answers!!!
Old Mar 31, 2009 | 07:59 AM
Inliner's Avatar
put the power steering back on the B16 and put it back on his car. same with the A/C
if he does not want either back on his car you have to loop the power steering lines coming out of the rack there is many threads on doing this. as for the A/C just remove all the lines in the engine bay and forget about it.
Old Mar 31, 2009 | 08:06 AM
but if i already dont have P/S or A/C on MY car, i dont have to worry about the lines or anything right? just disconnect it from the motor im swapping in??
Old Mar 31, 2009 | 08:29 AM
weavertime1's Avatar
You will need to switch your harnesses because the EK and EG harnesses are not the same as you probably know. Good luck!
Old Mar 31, 2009 | 08:34 AM
what? EG? where did that come from?
Old Mar 31, 2009 | 08:41 AM
and is it going to be a issue since its the JDM ITR motor with USDM wiring?
Old Mar 31, 2009 | 11:01 AM
You said your buddy had a hatch...I assumed it was a '92 to '95 (considered an EG in japan). Thanks...hopes that helps!
Old Mar 31, 2009 | 11:05 AM
lol...
read post #4.....
but either way... the questions still need to be answered...
Old Mar 31, 2009 | 11:08 AM
Then everything is plug and play...sorry I didn't catch that on post 4...Just trying to help man...Try to post all relevant information in one first post.
Old Mar 31, 2009 | 11:12 AM
and the help is much appreciated...
im guessing since his is already wired into a USDM, as long as i take all his wiring, ill be fine? Im hoping so...JDM ITR for cheeeeeeeeap.....WOOT WOOT!
Tong.Y
Aug 27, 2013 08:37 AM
JordanCivic
Jul 1, 2005 01:55 PM
prada_2o0o
May 25, 2003 08:48 PM
tooqwik1
Jun 16, 2002 08:44 AM
