B16B iacv replacement
Old Mar 29, 2009 | 06:30 PM
PhatwhipsJDMkits's Avatar
Default B16B iacv replacement
My question is what usdm iacv would i need to replace the jdm iacv? running obd1 so would a 95 del sol b16a work? all b series the same? please help erratic idle is drivin me nuts. also did try cleaning and it idled great then went back to the same ol problem after bout 3-4 hours of drivetime
Old Mar 29, 2009 | 07:38 PM
Default Re: B16B iacv replacement
ttt
Old Mar 29, 2009 | 09:32 PM
somebody has to know the answer here
Old Mar 29, 2009 | 10:19 PM
twiztid_989's Avatar
have u tried changeing throttle bodies
Old Mar 29, 2009 | 10:54 PM
no i have not changed throttle bodies i do not believe that is the problem same throttle body for over a year, and cleaning the iacv did temporarly solve my problem but then returned pretty sure i just need a new one just curious about which i need to replace it. im thinking i would need one for a 99-2000 SI due to both IM being obd-2 can anyone confirm this???
Old Mar 30, 2009 | 12:22 AM
V8 Eater's Avatar
your best bet would be to use the usdm itr one!
Old Mar 30, 2009 | 01:41 AM
Pensar71's Avatar
Can't confirm which one you need. But it should be the del sol 94iacv. Also try making sure the connections are nice and clean....
Old Mar 30, 2009 | 04:01 AM
94EG8's Avatar
Seagull Management
ITR IIRC, type R IACVs have a slightly different bolt pattern where they mount to the IM comparted to everything else.
Old Mar 30, 2009 | 04:23 AM
V8 Eater's Avatar
there is no doubt that you can use an itr one, the only question is would the other b16's work? I wouldnt even bother with a delsol and go directly to acura and buy an itr one!
Old Mar 30, 2009 | 08:18 AM
yeah thing is there isnt a local acura dealer closest i believe is over 4 hours away, also just thinking bout it after getting some sleep, doesnt the CTR ITR and usdm civic si share the same casting for intake manis? just ported differently or something... i dont know for sure but if this was the case mounting wouldnt be an issue right??
Old Mar 30, 2009 | 01:21 PM
94EG8's Avatar
Seagull Management
B16As use a different IACV than the CTR/ITRs Pic below, pic credits go to Katman
Old Mar 30, 2009 | 05:13 PM
well thanks that pretty much answers it all here goes 200 bux.......
wwbiker832
Feb 3, 2014 04:48 PM
frogjaw
Oct 26, 2013 09:14 AM
gokus-eg2
Aug 24, 2011 08:51 AM
B-Series Sol
Sep 3, 2002 11:56 PM
