hondata tuning question
i have an obd2b car, i want to switch to obd1 so i can have it tuned with hondata s200. am i able to just use the jumper at the ecu to convert it to obd1 or do i also have to get an obd1 dizzy?
You do not need to alter the distributor. Simply run an obd2 to obd1 ecu jumper & an obd1 ecu.
A plug & play system may come with a good enough basemap pre-installed on it to where you can drive the vehicle without issues. You need to tune the vehicle for the best result.
otakueric
10
May 22, 2004 06:07 PM
