5 Bolt Conversion
Old Mar 29, 2009 | 01:30 PM
styll_rydin's Avatar
New User
Default 5 Bolt Conversion
I have a 1999 GS Integra and I am thinking of doing a 5 bolt conversion. I can get my hands on a used 5 bolt set-up from a wrecked Type R. Can anyone explain what's the difference between the Type R and GS front brake, knuckle, and rear trailing assembly.
I have compared the OEM part #'s for both Type R and GS and the only thing I found different was the Hub-assembly. I know that caliper and rotor sizes are different. I'm just thinking if I can upgrade to ITR rotors and calipers and then remove my 4-bolt hubs and replace them with the 5 bolt hubs from a Type R? Would that work? What do you guys think?
Old Mar 29, 2009 | 04:15 PM
BlueIntegraBoy's Avatar
Default Re: 5 Bolt Conversion
Remove the knuckles and trailing arms and bolt up the new ones.
Old Mar 29, 2009 | 04:27 PM
cdntegintx's Avatar
You could just so what I'm doing and just upgrade the brakes. Its not hard to get the ITR calipers and re-drill rotors to work on the 4bolt set up
Old Mar 29, 2009 | 05:05 PM
New User
I would but I already have spoon calipers for the 5 bolt set-up and rotors as well. So 5 bolt hubs would not fit the 4 bolt knuckles and trailing arms? I know I can custom make a bracket for the spoon calipers and make them fit on a 4 bolt setup but there's better wheel choice with 5 bolt
Old Mar 29, 2009 | 09:14 PM
THE GUY's Avatar
Not to be confused with "THE MAN"
is this young-richie??
mattsnooz
Jun 29, 2008 09:03 AM
k0rupt_ed
Mar 2, 2008 06:46 PM
krazyhmongboi
Nov 12, 2006 11:04 AM
VTAC-KAT
11
Nov 2, 2006 03:19 PM
EL Vap133
Apr 6, 2004 11:44 AM
