head gaskets?
Old Mar 29, 2009 | 12:34 PM
civ97's Avatar
Default head gaskets?
Is there anyway to tell when a head gasket is going out
Old Mar 29, 2009 | 12:39 PM
obuhmyuh's Avatar
Default Re: head gaskets?
there are probably a million threads on h-t about the symptoms of a bad headgasket. you should start with the search feature.
Old Mar 29, 2009 | 12:47 PM
civ97's Avatar
i already tried searching and didnt find anything
green99civic's Avatar
Well one rough start, lots of white smoke coming out of the tail pipe (means Coolant), lose of coolant.
Old Mar 29, 2009 | 12:49 PM
civ97's Avatar
Thats what i have been noticing, its not a horrible amount, but when i run it, as soon as you shift some white smoke comes out, and i just started noticing my coolant resevoir getting a little lower
Old Mar 29, 2009 | 12:52 PM
civ97's Avatar
i assumed it probably was the head gasket starting to go but i wanted to get a few other opinions first. so say that that is wats wrong, will it be ok for about two weeks will i can get the parts? as long as i keep coolant on it
Old Mar 29, 2009 | 12:55 PM
civic_driver's Avatar
The trick when you search is to select to search in Title only and select the forum in which you want to search. Here, I've done that for you: https://honda-tech.com/search.php?searchid=1108867
Old Mar 29, 2009 | 12:57 PM
You should be alright along as you don't get on it, and go on long trips cause you can warp your head if the motor heats up to much which happens when you have an blown head gasket. If you do drive it and one day you come out and there is a tone of white smoke coming out the tail pipe i would drive then until you get it fixed.
NENET
Jun 19, 2010 11:02 AM
kasperxtcy
Apr 3, 2010 11:36 PM
D3vin
14
Mar 14, 2010 08:41 PM
buddy190
Feb 7, 2009 11:14 AM
BOOSTEDgreeneg
Jul 8, 2004 01:34 PM
