valve adjustment
Old Mar 28, 2009 | 06:05 PM
SsB_Db8's Avatar
Icon2 valve adjustment
i was wondering what would happen if you did a valve adjustment wrong. like for example your suppose to turn the crank counter clockwise and in the order of 1-3-4-2. but i did it clockwise 1-2-3-4 and made sure each cylinder was tdc. the motor runs but not like it did before the adjustment, should i just readjust it going counter clockwise dont want to mess up the motor.
Old Mar 29, 2009 | 09:37 AM
kingofbattle909's Avatar
Default Re: valve adjustment
? wow... re-adjust. and turn the crank "properly"
Old Mar 29, 2009 | 10:08 AM
tlchkc's Avatar
you got to redue your timing belt now since it you did it wrong.
Old Mar 29, 2009 | 10:21 AM
letsdrive's Avatar
yeah.... if you turned it clockwise the belt may have slipped a tooth. make sure its counter-clockwise and 1, 3, 4, 2. you can readjust the belt without ripping everything apart. just make sure the crank tdc mark lines up when the cams are tdc.
Old Mar 29, 2009 | 03:11 PM
95 integra's Avatar
You dont have to redo your timing belt. Since the Integra doesnt have an auto tensioner, it really doesnt care which way you turn the engine (if it doesnt slip one direction, its not going to slip the other....says the laws of physics).
BTW, just to make sure....#1 cylinder is the furthest on the right.
Old Mar 30, 2009 | 08:46 AM
HeikDiesel's Avatar
When standing looking at the engine.
Old Aug 19, 2009 | 07:06 PM
jdm_manny's Avatar
when doing the valve adjustment do u turn the crank 90 degrees or 180 degrees?
Old Aug 20, 2009 | 04:57 AM
civicgsr's Avatar
mkay:
http://importnut.net/valveadjust.htm
Quick answer: 90 degrees
Old Aug 20, 2009 | 12:39 PM
Circusraven's Avatar
Originally Posted by civicgsr
mkay:
Wrong. You turn the crank 180 degrees, which will turn the cam gears 90 degrees, to get you to TDC on the next piston.
Just double check that you're at TDC, and that you didn't skip a tooth on the belt for some reason. I don't think you doing them 1,2,3,4 would have too much affect...as long as the piston you were doing at the time was actually at it's proper TDC.
Old Aug 20, 2009 | 12:50 PM
aemintgsr's Avatar
It doesnt matter as long as you're turning the engine and then when you feel that the valves are loose then you do the adjustments
Old Aug 20, 2009 | 01:37 PM
Sorry, but what does that even mean?
Old Aug 20, 2009 | 06:42 PM
civicgsr's Avatar
Haha...whoops I do know that...I was thinking of turning the cam 90*. I only watch the cam as I crank the engine over.
Old Sep 4, 2009 | 03:41 PM
jdm_manny's Avatar
hmm ok thnks. cuz my understanding is that you start at tdc with the #1 piston, rotate the crank 180 degrees then go 2 the #3 piston, then again 180 degrees go 2 the #4 piston, then another 180 degrees and go to the #2 piston, and after that go back in the same order to recheck 2 make sure none are loose?
does this sound right??
but ive also heard u can do that order n only turn the crank 90 degees?
stagen
Dec 21, 2008 07:31 AM
ampm
12
May 3, 2007 10:53 PM
RTW DC2R
Mar 23, 2005 06:13 PM
98-ls
Mar 19, 2004 06:22 PM
PatEJ6
Apr 11, 2002 09:21 AM
