NEED HELP will a 99 civic si pass smog if...
Old Mar 28, 2009 | 01:55 PM
Jason P's Avatar
Default NEED HELP will a 99 civic si pass smog if...
Need help I might be purchasing a 99 civic si. The stock motor code I believe is b16a2 (usdm).
The guy is telling me he had the motor replaced with b16a (jdm) a few years back.
I am wondering if the car will pass smog?
Let me know!!
He said he had it pass smog few months back so wana make sure.
Old Mar 28, 2009 | 02:33 PM
IhateworkingoncaRs's Avatar
Default Re: NEED HELP will a 99 civic si pass smog if...
It should, if there is no check engine light currently on.
Old Mar 28, 2009 | 02:47 PM
jerryegk24's Avatar
where you from CA, no it will not pass visual because it's jdm motor but seen like your icon said sacramento, ca so it depend on the smoger. it will pass smog if the crank sensor has been place on the jdm b16a but it depend if the smog guy will smog it because it's jdm motor.
Old Mar 28, 2009 | 09:38 PM
R666_EK's Avatar
Yeah California sucks for smog. It all depends on the smogger. You might get lucky since its supposed to have a b16 he might not even notice the missing number. Worth a shot. Take it to a no pass no pay shop.
Old Mar 28, 2009 | 09:58 PM
angel_i's Avatar
yep ^ what he said
Old Mar 28, 2009 | 10:03 PM
Davus's Avatar
Older engine, newer car, etc: What particular year is this engine? (They ran from 88 to 2000'ish)
Old Mar 29, 2009 | 08:14 AM
packman5280's Avatar
i swapped a jdm b16a into my 2000 si, and it passes smog tests in colorado. different state obviously, emissions are easier in co than ca. as long as the person who did the swap just did the long block, kept all the sensors from the stock motor, you may be ok though. i had to change the oil pump to keep the crank position sensor, but no lights and it passes emissions. good luck.
turbob16ferio
12
Dec 26, 2010 07:48 AM
olddohc
Nov 20, 2002 01:48 PM
Dashu
Oct 28, 2002 10:16 PM
Spade
Oct 12, 2001 07:38 PM
