Head gasket issue
Old Mar 28, 2009 | 01:35 PM
kja5070's Avatar
Default Head gasket issue
Well, i was in the process of fixing my head gasket when i realized that my fel pro head gasket doesn't fit properly. 8 of the 10 holes for the head bolts line up, except for the two on the outer corners near the intake manifold. So, i was wondering if anyone has had this problem before and what gaskets fix properly. I should have just gotten an oem honda gasket
almost forgot. i have a 1990 civic dx with a d15b2. On the package it says that it is for a d15b2, but its not. I also lined it up with a cheap generic gasket ive have for a while and it is exactly the same.
Old Mar 28, 2009 | 04:33 PM
boostedefhatch's Avatar
Default Re: Head gasket issue
i had the same problem, flip it over worked perfect everything matched mine was upside down
Old Mar 28, 2009 | 04:45 PM
Twisted Image's Avatar
look at head gasket
look for word UP on it
place that side facing up
Old Mar 28, 2009 | 06:49 PM
kja5070's Avatar
well that makes me feel dumb, but it lines up perfectly if you put the up side facing down
Cho0se
Feb 24, 2020 02:59 PM
ntoxicatedtigah
Nov 26, 2008 10:47 AM
Straits514
Apr 20, 2006 12:48 PM
king tuck
Oct 7, 2004 04:15 PM
