Bad PCV Valve...??
Old Mar 28, 2009 | 12:56 PM
JDM_SOHC's Avatar
Default Bad PCV Valve...??
My PCV valve lets air travel one way effortlessly, and when u try to blow air in the other end its letting air in but not nearly as high a rate as the other side, but it still lets a minimal amount of air get blown in, is this bad..?? There was also oil covering the whole bottom part of the valve upon removal..
Old Mar 28, 2009 | 01:20 PM
civic_driver's Avatar
Default Re: Bad PCV Valve...??
i hope you didn't put the dirty thing to your mouth
Old Mar 28, 2009 | 01:31 PM
hondachris1994's Avatar
Shake it, if it rattles its good. If it doesnt rattle replace it
Old Mar 28, 2009 | 01:32 PM
SiYouLater's Avatar
**** a PCV valve is only like 5 bucks. Replace it.
Old Mar 28, 2009 | 01:34 PM
Former User's Avatar
The valve should allow easy air flow toward the IM and no air flow in the opposite direction. Just replace the valve as it only costs a few dollars.
Old Mar 28, 2009 | 01:44 PM
Shawn C's Avatar
In The Garage
yep. its a pcv valve
Old Mar 28, 2009 | 01:58 PM
JDM_SOHC's Avatar
i put a peice of syran wrap "sp?" over it an poked a hole in both ends... yah ima replace it anyways i was j/w if this meant it was shot just for future reference...
dannyly17
Jan 14, 2011 08:20 AM
Civic082382
Oct 29, 2008 01:19 PM
beanbag
Aug 7, 2007 04:34 AM
Engn
Oct 7, 2003 05:02 AM
