suspention problem....
Old Mar 28, 2009 | 10:32 AM
hannslebo's Avatar
Default suspention problem....
ok...so i got some KYB struts and bought some lowering springs off ebay...well i work 6 days a weeks so im fairly busy and i would have liked to put all this stuff on myself...but i had a mechanic do it...and i was about to go get it aligned. and was raising my car from where i had it b/c it sat TOO LOW...and when i was messing with the back driver side i noticed it was kinda loose....well i took the carpet **** out from around it and noticed my strut was poking up through the hole and the rubber piece on bottom was just sitting on top of the spring...the place that i use to put them on is closed from SAT-MON...do you guys know what i can do to get it to stay down and in place or what....???
Old Mar 28, 2009 | 10:40 AM
EK2.0's Avatar
Default Re: suspention problem....
You mean the strut shaft is poking way up out of the top of the hat?
Sounds like they forgot to put the metal keeper/washer on the shaft before bolting on the top hat.
Old Mar 28, 2009 | 10:45 AM
alphalanos's Avatar
They didnt put the washer on correctly on the top of the shock shaft. Youll have to disassemble the shock/spring and redo it. Id check the rest of the work too.
Old Mar 28, 2009 | 10:46 AM
hannslebo's Avatar
yea...the silver shaft is coming up into my trunk...
Old Mar 28, 2009 | 10:51 AM
EK2.0's Avatar
yeah like the other guy said, take to strut/coilover off the car and remove the top hat and you'll need to put that washer on the shaft and then reinstall the top hat.
Old Mar 28, 2009 | 10:58 AM
hannslebo's Avatar
ok...ill prolly just end up taking it back up there and makin them do it...i just dident wanna hear any BS from them. but i appriciate the help
Old Mar 28, 2009 | 11:12 AM
EK2.0's Avatar
LOL they should fix it and if you really wanted to push it you could prolly get that whole job done for free cause they messed up, big time!
mandeecandeex3
Suspension & Brakes
Apr 17, 2013 02:02 PM
itrhopeful
Nov 29, 2004 01:17 PM
patastinky
Jun 13, 2003 04:28 PM
Agent STFU
10
Apr 1, 2003 12:41 PM
animated_life
Jan 3, 2003 10:49 AM
