Electrical Problem
Old Mar 27, 2009 | 06:46 PM
Hill4589's Avatar
Default Electrical Problem
Ok before I start let me just say **** this car..
92 Civic Hatch CX with D16Z6 swap
So anyways to get to the problem, for the past 3 days my gauge cluster battery, oil, seatbelt, and brake light have stayed on/ flickered without the key in the car after i turn it off. Sometimes even the car will stay on for a few seconds to minutes then sputtering and shutting down but with the lights still on/flickering and the key taken out of the ignition. It has been raining for the past 3 days here just for background info if that helps. Since I havent had time to work on it until tomorrow today it decides to **** me over and I go outside to give it a jump and me having ADD I accidentally put the positive terminal on the negative terminal and negative terminal on the positive terminal on the car being used to jump mine (I need to start paying more attention). So now with the terminals properly connected I go to start my car and I got nothin. A completely dead battery, no headlights, no heat/air flow, no door ajar beeping, no clicking when turning the key, but hey, i got a horn still? wtf..
Old Mar 27, 2009 | 07:16 PM
Former User's Avatar
Default Re: Electrical Problem
1) Check all the fuses under the hood. Some may be blown.
2) Clean the battery posts, connectors, and ground wire with steel wool. Remove the battery and have it tested at your local auto parts store.
3) You have a bad ignition switch that needs to be replaced.
Old Mar 27, 2009 | 07:56 PM
civic_driver's Avatar
Something might be up with your alternator. Check it out
Old Mar 27, 2009 | 08:54 PM
Hill4589's Avatar
I looked at the fuses but Im not sure what they look like blown they looked ok to me.
The car should have started without the battery or alternator if its hooked up to another car right? My car ate an alternator a few months ago so I had to replace that with one outta my buddies parts del slow.
Old Mar 27, 2009 | 09:01 PM
Remove each fuse and check for continuity across the two terminals. Start with big fuses 41, 40, and 39.
Have the battery tested.
Another possibility is that you fried the under-hood fuse box.
Old Mar 28, 2009 | 10:36 AM
Hill4589's Avatar
Ok so I checked the fuses under the hood again and turns out the battery fuse was blown so replaced it and it runs again but still the flickering lights problem. Im gonna go grab the ignition switch from my friends parts del sol again and see if that fixes it. Thanks for the help guys ill keep posting with results
Old Apr 1, 2009 | 05:49 AM
Hill4589's Avatar
Update: Ok so the weather background actually comes in handy. Today it rained and my cluster lights haven't flickered since the last rain. The problem exactly is the battery light, oil light, seatbelt light flicker on and off rapidly and the temp guage flutters up and down with the pulse of the lights, like if you would turn your key in the ignition very fast thats what it would do. This is all when I shut the car off. When its on they do not flicker.
10 Minutes into driving in the rain today my right turn signal stayed on solid both on the dash and the actual corner lights stayed on.
I'll try to get a video up later. Thanks for the help so far
Old Apr 1, 2009 | 06:10 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
i would def be to check out ignition switch...you even said "like if you would turn your key in the ignition very fast"
if you think about it, when your first turn your key to accessory when starting the car right before you turn further to start, all of those lights come on....your ignition switch is f**ked...
as far as your headlights flickering, check all of the fuses in the main relay box as Ron said....
gl
Old Apr 1, 2009 | 10:40 AM
87supraT's Avatar
My cousins 96 civic is having a similar problem. When she takes the key out all of the electrical components stay on. The only way she can get them to go off is to pull the negative battery terminal. Did you ever figure out what your issue was?
Old Apr 1, 2009 | 10:57 AM
Hill4589's Avatar
gl
the thing is it only happens when its wet outside and the ignition switch is not getting wet.
Hill4589's Avatar
Working on it right now
Old Apr 1, 2009 | 11:05 AM
superbean's Avatar
just replace the ignition switch
Old Apr 1, 2009 | 06:15 PM
Hill4589's Avatar
What for when this only happens when it rains? On start up this morning my car was fine because I hadn't gotten the wheels spinning yet to throw water up wherever its going to mess something up. After a while then it started once water got into those naughty places.
Old Apr 2, 2009 | 11:15 AM
Hill4589's Avatar
Video update: I took this video yesterday and I have another video on my page from a few months ago when this occurred before. Someone has to know something.
http://www.youtube.com/watch?v=94rdzt3bj28
http://www.youtube.com/watch?v=MgJgRa7vR2s
Old Apr 2, 2009 | 11:26 AM
The ignition switch may not need to get wet with rain water to malfunction. It may be the higher humidity in the air when it rains that triggers the problem.
JDM.Accord
Jun 18, 2015 03:47 AM
Jish
Jul 13, 2009 05:55 AM
ELHatchyBlanco
Jan 23, 2004 02:13 PM
peterboroughkid
Jun 17, 2003 06:19 PM
dphi
Apr 29, 2002 09:00 AM
