i need d16z6 help badly please someone
ok just rewcently swapped my d15b7 to a z6 just for a lil more power .ok got everything hooked up try to start it will run but sounds like a wrx,did the right firing order compression in all 4 cyls read all 180. u can pull out 2 plugs run like crap and the other 2 it runs the same the number 4 arced bad but others didnt any ideas at all please help!!!!!
Sounds like 2 out of the 4 cylinders are not firing.
Check whether the 2 injectors for the bad cylinders are clicking and getting power. Also check the distributor cap, rotor, and plugs for wear and corrosion, and whether the plug wires have the proper resistance.
see he understood me... but sorry let me help better. i can pull number 3 and 1 off not at same time but u know and it will run the same. but if i pull off4 and 3 it will run like a wrx.. i dont get it and the compression was 180 in all cylnders.i used the rotor and cap off my d15b7 dizzy . nothing still same ... the d15b7 ran there are wires hacked on the tps sensor i just noticed but why would that affect if its running like that ???
#1 and #3 plugs or wires may be bad. Also check whether #1 and #3 injectors click when the engine is idling.
A bad TPS would not cause specific cylinders to misfire.
i thinkits quite evident that 1 and 3 are not firing so start from the spark plug and work your way backwards to solve the problem, plugs, wires cap and rotor, igniter... get the idea
Mar 15, 2004 05:52 PM
