help car wont start after new clutch install
Ok so here’s my problem. I have a full AFI kit on my ls/vtec and just smoked my act clutch and so I order a new one clutch. So I pull the tranny off take the clutch off while im in there I replace rear main seal for preventive maintenance. I get the new clutch installed tranny back on lower my car from the lift and now it doesn’t start. I've checked all plugs dizzy I’ve tried a couple I know they worked. I have spark fuel and the timing is dead nuts. it just cranks and cranks
Not a whole lot to mess up there since it does crank over do like the others said check all your connections and make sure you have all your grounds connected back correctly.
