well 60-1 garrett fit on my block
i have a cast iron rev hard manifold. well my 60-1 t3 fit my manifold onto the block or well i have to switch it around so hot side is pointed to tranny side?
so chop block for turbo to fit!
or
flip turbo around and get new downpipe and charge pipes wield!
or
It depends. The 60-1 is one of the few compressor wheels that can fit in 3 Garrett covers. T04B (such as my silver surfer), T04E, and T04S. The t04b can easily fit without notching the block, the E may take some work, and the S will be a pain. which one do you have?
The Gen2 Silver Surfer has a slightly shorter inlet, but the OPs concern was the housing hitting the block. The silver surfer will not.
#1 question 4 or 5 bolt outlet >?
5-bolt outlet yes- with enough block grinding will fit
4-bolt no way in hell unless you have a t04B housing which i doubt
That problem was a little different. that was based upon the compressor INLET, not the housing (from what I gather here). The Gen2 Surfer doesn't have that problem any longer.
DELshaneSOL
Mar 12, 2012 12:23 PM
