Oil Feed line to Turbo
Old Mar 27, 2009 | 05:17 AM
Boostinb20!'s Avatar
Icon2 Oil Feed line to Turbo
Today I got my turbo installed and was running my -3 oil feed line.
My question is can I use a Brass 1/8 to -3 90 degree elbow fitting that screws into the turbo. Im worried that maybe the heat will cause an issue cause the fitting is made of brass rather then steel????
Old Mar 27, 2009 | 07:06 AM
HiProfile's Avatar
Default Re: Oil Feed line to Turbo
Brass will melt at about 1800F last time I looked, egt's from a HOT turbo motor will be under 1600F. The CHRA will never get above 400F, and the fitting never above 300F due to the oil, which should enter at 200-240F.
black98gsr-t
Sep 7, 2005 05:45 PM
slo_crx
Oct 12, 2004 05:51 PM
