b16 bogs at WOT
Old Mar 27, 2009 | 12:00 AM
hatchet_honda's Avatar
Default b16 bogs at WOT
i have a 90 dx hatch with a b16 swap. well had a code for the crank angle sensor and turns out i forgot to switch the tps wires. that fixed the cel. but now when i punch it it bogs and wants to stall at WOT. if i feather the gas itll accelerate. i tried switching the tps wires back and it still does it. swapped out tps, map, 02, checked ignition timing...all good.
i did recently slap on an exhaust i took off my 90 si when i installed a catback. decided to use it so i could pass emissions(which it failed high c02 and hydro carbons) clogged cat maybe???
Old Mar 27, 2009 | 07:08 AM
aaronhume's Avatar
Default Re: b16 bogs at WOT
no CEL? it sounds like its giving too much fuel then the engine should have. does vtec engage? at what rpm range does it bog down at WOT?
Old Mar 27, 2009 | 07:16 AM
gringo7718's Avatar
Assuming timing is good, and fuel pressure is good, it sounds like a weak ignition system. I had a similar problem when my msd coil went bad on me. As you increase load, the fuel system adds more fuel and a weak ignition system cannot ignite the mixture. Check your ignition system - plugs, wires, distributor cap, coil.
Old Mar 27, 2009 | 10:26 AM
vtec kicks in fine but i have to blip the throttle to get it to rev that high. if i slowly press the gas pedal it will rev up but if i floor it the engine bogs and sputters.
Old Mar 27, 2009 | 10:30 AM
could it be the other way around? ignition good but not enough fuel? ive replaced the fuel filter, fuel press is good but i swiped my injectors from an ls in the junkyard...maybe its a pooped injector
Old Mar 27, 2009 | 12:11 PM
head458's Avatar
map sensor maybe?
Old Mar 27, 2009 | 07:32 PM
gringo7718's Avatar
It could be a lack of fuel pressure/volume. How long ago did you swap injectors? If you swapped injectors and then it started bogging - maybe its the injectors? Try your old fuel injectors and see what happens.
To test fuel pressure, you really need to test it under load. Hook up a fuel pressure guage to the fuel rail and duct tape the guage to the windshield. Go for a drive and see if the pressure drops.
Old Mar 28, 2009 | 01:05 AM
well i didnt have injectors to begin with....started from scratch with this build so i just swiped some from the junkyard to get it running. i never noticed the bogging untill i slapped on the exhaust. i drove it up and down my road a few times with just the header and no exhaust... i didnt really ever get on it but it never bogged like it is now
Old Apr 3, 2009 | 10:44 AM
well today i advanced timing via the dizzy all the way and it has improved but still sputters and bogs out. is there an easy way to check an injector? i have a few layin round that i could swap out if i found a bad one
Old Apr 3, 2009 | 11:07 AM
90hatchie09's Avatar
run the car at idle disconect injectors 1 by 1 if it idles down its fine if u disconect nd see no change that injectors bad
Old Apr 3, 2009 | 11:15 AM
thats a good idea thanks....ill give it a try
Old Apr 3, 2009 | 11:27 AM
well that eliminates the injectors being the problem i guess....idled down everytime i unhooked one. gotta be the damn timing. ok, the white mark on the crank pulleyis tdc right? maybe the timing light was all f'd up
Old Apr 3, 2009 | 05:37 PM
vanpachi91's Avatar
New User
im having the same proble with my swap too i have a 91 civic with a b20 mine tacks out at 4 in every gear......
what can be wrong.....i also tried different ecu's
note: my car used to be duel point.....
Old Apr 4, 2009 | 08:06 PM
what ecu are you running?? any check engine light?
Old Apr 4, 2009 | 08:21 PM
bradyj001's Avatar
sounds like the same problem my car has, i think its the fuel pump in mine because if you clamp my return hose off the bogg goes away.. try that and see what ya get.
Old Apr 5, 2009 | 10:18 AM
aaronhume's Avatar
are you using a chipped ECU? it could be giving it too much fuel at WOT, but it would have to be a lot to make it bog down... and for timing, the white mark is TDC when you align your cams and crank, but when the engine is running, use a timing light to get the ignition timing on the red mark.
Old Aug 18, 2009 | 07:38 PM
ef2_civic's Avatar
Need help with this
Old Aug 18, 2009 | 07:42 PM
ef2_civic's Avatar
Need help with this!! Same thing expect mine actually dies & when full throttled. It is up on stands haven't tried 2 drive it.
I have checked what was advised up in here but nothing still present my bogging/dying issues.
Someone can help or relate please pm me or get me any info 2 a mechinac don't have much time I'm a workalic. LoL
Old Aug 19, 2009 | 09:02 AM
01S2king's Avatar
did you try a new o2 or a used one. i would get a new oem one from honda.
Old Aug 22, 2010 | 06:41 PM
hondoctored95eg's Avatar
im having the same problem to but when i pull my plugs the look lean but it acts like its fouling plugs and i checked my injectors and when i put new plugs in it runs fine
Old Aug 22, 2010 | 06:46 PM
Eaglekper0046's Avatar
Disconnect one plug wire at a time, it should miss fairly bad. If you have good spark you could have a bad cylinder. My A6 motor is doing the same thing.
Old Apr 17, 2018 | 11:07 PM
Matt_ek4's Avatar
sorry to dig up an old thread but what was the issue? As it sounds exactly the same as what ive got going on?
JDMCIVIC919
Nov 17, 2011 03:40 PM
koczeka
19
Aug 31, 2007 08:43 AM
foumer
Feb 9, 2005 11:52 AM
itr--779
Apr 24, 2002 12:13 PM
