Coolant leak from rear of the motor (Driver side)
Old Mar 26, 2009 | 06:11 PM
Vampire2o9's Avatar
Default Coolant leak from rear of the motor (Driver side)
Hi, I have a 1990 DA integra. Usually after about 4 days of driving I would notice I have low coolant. There hasnt been much leakage under the car. A couple weeks ago there was. Now it just seems dry. After a pressure test to find the leak came up nothing, I decided one day to roughly drive it. (today lol)
After I parked it, I started noticing drips from the driver side, behind the motor. When I looked under its a little above the oil plug/pan, and a little to the left. A long time ago on my crx I had this same leak but it was a hose in the back of the motor underneath the manifold. Does the integra have the same one?
Also what would this hose be called, if it is. I can't really get a good view of it, but I also noticed a piece of plastic was on the ground. O_o?
Thanks for any help with this matter.
Old Mar 26, 2009 | 07:02 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Coolant leak from rear of the motor (Driver side)
There is a pipe running between the thermostat housing and water pump, with several hoses attaching to it. Could be any of those, or it could be the o-rings on the pipe.
Old Mar 27, 2009 | 06:44 PM
Vampire2o9's Avatar
Thanks! I got it. Its a pipe that one side is headed to thermostat housing and the other to the water pump. The thing was rusty and cracked. Its going to be a &^*( trying to get that done. =/
Tour991
Honda Civic (2001 - 2005)
Apr 16, 2013 07:11 PM
Mishako129
Apr 11, 2013 05:01 PM
2kgsrt
Apr 5, 2010 09:00 PM
immrtaltchnq
Aug 28, 2006 10:06 AM
LudeyKrus
Aug 3, 2004 12:38 PM
