B-Series engine swap Help plz!!!
i have a 98 Dx, and i want to put my built Obd1 LS into my car,and i dont know how to wire it up.. so i need help on everything i have a jumperharness for my obd1 ecu and thats it.. i dont know if i use my obd2 wire harness or the obd1, and so on, im sure wires are gonna need to be cut.. but some one please point me in the right direction
What about the sensors and stuff that dont match up.. i know i need a jumper harness for my dizzy,either that or switch to an obd2 dizzy..need more info, keep it coming!
If i use my Obd1 harnesss, then how do i take care of were the Obd1 harness plugs into my exsisting obd2 haress.. i think obd2 has one plug on the left and right side, and i believe obd1 had two or three plugs. and none match up to mine
You can't use the OBD1 harness. Your car (and all other '96-'00 Civics) have a 1-piece engine harness, where the OBD1 Civics and all Integras have a 2-piece harness. So you have to use your OBD2 harness.
Besides the distributor, the injectors and alternator have different plugs. You could just use OBD2 injectors, but the stock DX (LX & CX) ones are only 190cc (commonly claimed by people, but I don't know personally). So either find some other OBD2 injectors, or get some OBD1 injectors and wire in the connectors to the harness. For the alternator, either get an OBD2 one or swap the voltage regulator (the part with the plug) from your stock alternator into the OBD1 alternator.
sol-oto
Sep 1, 2009 12:43 PM
