pr3 81.5mm on pistons on ls/vtec( PROS ONLY)
hey guys i am new at the ls/vtec and i bought the arp head studs and arp rod bolts,and golden eagle converter iol line,and i have a b18a1 and i am going to bore it to 81.5mm and get it hot tanked and stuff,
is the pr3 pistons good,or have you guys heard of them.
ive heard something about a few people using them,LOL!!!!
edit: ill be nice. search through this,it should give you a idea of what will work
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/lets-see-your-1-8l-oem-bottom-end-allmotor-91-octane-dynos-1263436/
pr3 would depict the piston dome match a b16a motor, 88-91 B16 motor to be exact.
here is a site showing the diffrent dome types on honda pistons
http://www.ff-squad.com/tech/temp/pistons.htm
www.zealautowerks.com
Also, read this and let this be your lsvtec guide.
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/how-build-%22reliable%22-lsvtec-b20vtec-1676914/
im not a pro so i would like to hear too...lol... seriously though ...the pr3 pistons would work nice on a mildly street build motor...all depends on what you are planning to use the motor for.
If you are refer to the rs pistons pr3 pistons? I actually have the 82mm version of these pistons. I have no issues and pushing over 200hp....
Bring up a compression calculator and figure it out. With that said, I run PR3's with a GSR head in a B1 block (81.5mm) Bumps compression enough to make a difference but can still run on 92 octane fuel. I think I am around 11.5-1 11.7-1.
Hope that helps.
Hope that helps.
the.hamburglar
May 17, 2009 07:51 AM
LS/VtecCrew1
Mar 29, 2009 12:27 PM
