does anyone know...
It's some like glue that you put on the thread of the screw when you put it back in. It's cheap you could find it like at autozone. It's like a couple bucks. Pretty much guarentee it won't come out anymore. If it's the screw that keep coming undone on the rotor that is.
Yeah you can buy it and your car will still crank but won't turn over right? That's a temporary fix. That's what I did and it worked well till I could get a new dizzy. As for other fixes I did what I could be a budget baller! You can ask at the store for loctite (Sorry for the miss spelling). They will be able to help you. There were different colors for different strengths.
yeah, i would recommend loctite 242. the 545 is mostly for a liquid seal, pipes, fittings, ect. the 290 would work, but you'd never get the screw out. its for heavy duty vibration proof aplications.
the problem is that at the junkyard every single distributor in every honda is alredy gone! coils go bad alot in honda's i heard... so i just put a screw i found that fits just right. so loctite 242 it is =D
Don't go buck wild with the loctite, just use a small dab on the side of the screw. Also, I've had this problem in the past too, make sure the screw didn't get lodged between the rotor and something else, and damage it. I had an ignotor get murdered that way before.
hotdoggies
30
Dec 25, 2010 04:34 AM
TiggsCRX
15
Mar 21, 2004 04:00 AM
