were is the Thermostat on a B16a
Old Mar 26, 2009 | 05:11 AM
hatchyksp's Avatar
Icon6 were is the Thermostat on a B16a
the temperature gauge in my car is not working. it worked the other day but now its dead, could it be a short? or do i need another thermostat.
hatchyksp
Old Mar 26, 2009 | 06:56 AM
dephtone's Avatar
Default Re: were is the Thermostat on a B16a
On a b16a you will probably looking for the Coolant Temp Sensor. If this is not working properly this sensor is probably dead. It's on the head right below the upper radiator hose. It's a 1 prong plug.
Old Mar 26, 2009 | 07:50 AM
gringo7718's Avatar
Thermostat is a mechanical device to control the flow of coolant.
The coolant temp sensor is a two wire sensor in the head under the distributor. It sends info directly to the ECU.
The Coolant temp sending unit is a one wire sensor in the head that sends info only to the guage cluster. If your temp guage is not working check this circuit.
Old Mar 26, 2009 | 07:53 AM
JDMgunmetalCRX's Avatar
the thermostat is located on the block. its inside the top hose going to the radiator. disconnect that hose from the block and you will see it there. just replace it and go over it with silicone. and u should be fine.
Old Mar 26, 2009 | 08:30 AM
gringo7718's Avatar
The thermostat is purely mechanical and has nothing to do with his temp guage not functioning. He has an electrical problem between the Temp Sending Unit and his guage cluster.
Old Mar 26, 2009 | 08:34 AM
dephtone's Avatar
Just as an FYI though if you go to an autoparts store to buy a new one, they have it listed as a Coolant Temp sensor for the sending unit, atleast thats how Advance Auto Parts had it, they had to pull both parts to make sure I got the correct one. Make sure you get the 1 prong if your gauge isnt working.
93del
Dec 19, 2010 09:49 AM
type Gendy
Sep 7, 2009 01:07 PM
Valetin831
Jan 24, 2008 05:13 PM
asiansgoweeee
Nov 3, 2004 08:03 AM
2000_Civic_Si
Apr 3, 2002 09:03 AM
