Final Drive for the ITR
Old Aug 13, 2002 | 04:29 PM
36Chambers's Avatar
Default Final Drive for the ITR
Why do u change the final drive for R, curious cuz i see that alot do.. what does it do diferent from the stock one.
Don't flame here .........just need info
[Modified by TypeR690, 6:29 PM 8/13/2002]
Old Aug 13, 2002 | 04:36 PM
Back in Black's Avatar
Rather OG
Default Re: Final Drive for the ITR (TypeR690)
It modifies shift points. Basically, it's a life-safer and helps compensate for the lack of torque our motors produce.
Jason-
who his ATS fd, but would rather have the gear set...
[Modified by Jason Franza, 8:37 PM 8/13/2002]
Old Aug 13, 2002 | 04:41 PM
36Chambers's Avatar
Default Re: Final Drive for the ITR (Jason Franza)
so what would the shift points be when the final drive has been changed
1st ?
2nd?
3rd?
4th?
5th?
thanks
Old Aug 13, 2002 | 04:43 PM
norice's Avatar
Search for ATS. This has been discussed lots recently.
Old Aug 13, 2002 | 05:11 PM
Big Teggie's Avatar
Default Re: Final Drive for the ITR (norice)
Check out a search. You should be able to pull up alot of info about final drives. All the goods and bads about switching it, whats involved, and what to choose from.
But anyways. I have a JDM 4.7 FD in my car, and would NEVER go back to a stock 4.4 final drive.
Old Aug 15, 2002 | 05:49 PM
hybrider's Avatar
Default Re: Final Drive for the ITR (Big Teggie)
http://www.autocrossing.com/cgi-bin/gearcalc.cgi
check it out
Old Aug 15, 2002 | 06:02 PM
baonest's Avatar
Default Re: Final Drive for the ITR (hybrider93)
that just for final drive... would there be any benefit to get the whole gear set as jason mentioned he wanted?? im sure there would be, but is it available
Old Aug 15, 2002 | 06:04 PM
disordeR's Avatar
# engine rotations to 1 wheel rotations. yes?
so a higher final drive will increase the number of rotations to 1 wheel rotation. more power quicker.
Old Aug 15, 2002 | 06:06 PM
Splat's Avatar
Collector-o-Guns and Drinker
Default Re: Final Drive for the ITR (baonest)
Changing gear set = custom ratios for each gear
Ideally, you could rebuild the tranny to optimize it for each track you hit, like the NASCAR guys do
Pat, who has torque now that he has b00st, and learned tonight that the roundy-round guys use rearend gearsets from 2.50 to 6.60
Old Aug 15, 2002 | 06:20 PM
Willard's Avatar
it's a life-safer
Old Aug 15, 2002 | 08:25 PM
1GreyTeg's Avatar
Default Re: Final Drive for the ITR (Willard)
it's a life-safer??
I won't say that exactly but, I'll say:
IT KICK'S F*CKIN ***!!!
Nuff said?
Oh, and do a search please in the nicest possible way because this has been covered a few more times than 1,000,000...
A.
thorshammer56
Honda Motorcycles
Jun 6, 2007 08:05 AM
s2kkid
Sep 27, 2004 12:58 PM
brasilracing
15
Sep 24, 2002 02:01 PM
underrated99si
Jun 23, 2002 08:13 AM
