B18C5 in 2000 Civic Si Chassis. What ECU?
Old Mar 25, 2009 | 09:49 PM
ixoiiiiviviiivi's Avatar
Default B18C5 in 2000 Civic Si Chassis. What ECU?
I dropped a b1c5 USDM ITR motor in my 2000 Civic Si. Using a B16A2 Engine harness. What ecu and setup will I need to get this running properly without spending a lot? I was told the following are worth a try.
P28 w/ OBD1-OBD2B Jumper
OBD2B P72
p73 w/ OBD2A-OBD2B Jumper
If there are any other options please let me know.
Old Mar 25, 2009 | 10:07 PM
ALLxMOTOR EG's Avatar
Vietnamese!
Default Re: B18C5 in 2000 Civic Si Chassis. What ECU?
You will need and obd2b P73 ecu if you want it to hook right up to your 99-00 civic si harness. 96-98 swaps are obd2a and 99-01 swaps are obd2b.A p28 ecu chipped would work with your swap but you would need the conversion harness.
Old Mar 26, 2009 | 12:12 AM
according to some. to use the OBD2B P73, I need to bypass the factory immobilizer which i hear is hectic...is this true...lemme know some more options or an easier way to bypass it...
Thanks
Old Mar 26, 2009 | 12:56 AM
Vietnamese!
Thanks
the plugs are different from 96-98 and 99-00. You would have to run a OBD converter harness in order to use a different R computer.
Easy, cheap suggestion. Get a P28 reprogrammed(OBD 1 ECU from a 92-95 Si and EX) for DOHC specs and run an OBD2-OBD1 converter harness. Prolly the easiest, most hassle free way to do it. GL
Old Mar 26, 2009 | 01:06 AM
STOCK_SOHC_DX's Avatar
I'm running a p28 chipped with jumper and runs great, stay away from the OBD2B p72 it was crap and I never had P73.
Old Mar 26, 2009 | 05:38 AM
my99civicsi's Avatar
New User
the obd1 ecu with a conversion harness will work great.. Just remember that if you have emissions testing in your state you will need an obd2 ecu to pass. For now you can get away with your p2t that came in your 2000 si, from what I can see its as good as the obd2a ecu from the gsr.
Old Mar 26, 2009 | 06:43 AM
Vindicator9000's Avatar
318 Curves, 11 miles
Thanks
This is true. You can carefully desolder and remove the immobilizer from inside the ECU (what I did), but you will throw a constant P1607 internal ECU malfunction code. It will run 100% normally, but you will have a CEL. I just reset it with my scanguage everytime I start the car.
Or, you can PM Katman. For a reasonable fee (think he was charging around $100), you can send your ECU to him and he will install a dummy chip where the immobilizer was that will disable the immobilizer and not throw a CEL.
These are your only two reasonable options if you want to use an immobilized OBD2B ECU in a car that it wasn't intended for. It applies to OBD2B ITRs, GSRs, and some H22s. I've heard of other ways, but they involve getting honda to program keys for you, which I'm sure they frown on for this sort of thing.
I'm not 100% sure about California, but from the horror stories I've heard, I don't think you'll pass inspection with an OBD1 or OBD2a computer in an OBD2b car.
Old Mar 26, 2009 | 09:51 AM
Vietnamese!
Originally Posted by Vindicator9000
Or you can PM Katman. For a reasonable fee (think he was charging around $100), you can send your ECU to him and he will install a dummy chip where the immobilizer was that will disable the immobilizer and not throw a CEL.
That is true,to the OP if you plan on bar(making it legit) in the future i suggest you get a dummy chip to disable the immobilizier in the OBD2B ecu(PM Katman).
California is strict about inspection.Since yours motor is USDM B18c5 here is a link to make a jdm itr bar'd,you get the idea,do all that with everything hooked up and you will pass.
https://honda-tech.com/forums/hybrid-engine-swaps-18/legalizing-your-jdm-itr-motor-906684/
Old Mar 26, 2009 | 10:17 AM
Vietnamese!
That is true, California has it rough.
Old Mar 26, 2009 | 09:36 PM
tried running it with the p2t...didnt run too well...not sure if its timing or compression issues. is this safe at all?
Old Mar 26, 2009 | 09:39 PM
so basically go p28 til smog...will the p28 run better than the p2t? will it need to be chipped?
Old Mar 26, 2009 | 10:01 PM
lsvtecturbosol's Avatar
I run an obd2b p73 I think is the one. Whatever one is obd2b and I just removed the immobilizer. I have that crappy constant CEL but I have the stock P2T to put in just to pass inspection. Doesn't run good but I drove it with the P2T for about a month with no issues. Just don't get on it.
I also have a p28 with crome ready for a tune as soon as I can find someone to do it for me.
That seems to be the hard part right now.
Old Mar 27, 2009 | 12:45 PM
Vietnamese!
From what i believe yes, p28 chipped for DOHC specs.BtW you need a conversion harness if running p28.
wallendiaz
Mar 14, 2013 07:27 AM
dkhuynh
May 24, 2005 02:27 PM
B18ek
Nov 27, 2004 07:39 AM
B18C 00 Si
Aug 1, 2003 08:21 PM
got rice
Mar 31, 2002 10:55 AM
