1994 Fuel Pump?
-1994 Accord Coupe
ive recently been experiencing some "occasional" problems starting. i always turn the key to the on position to hear the fuel pump do its thing before i actually start the car. So, when the car does not deiced to work happens to be when i don't hear the fuel pump.
my question(s)
- am I wrong in suspecting its the fuel pump?
- is it something i should replace now? (happens once or twice a week max but eventually always starts)
- Where exactly is the fuel pump located? (i dont have a manual and google wasnt really giving me a definitive answer. under the seat or in the tank?)
thanks in advance
my question(s)
thanks in advance
test main relay if it test good, then drop tank and replace fuel pump. and try to to run it to e all the time either as that definately shortens the pump's life since the gas is what cools it
whelp i finally had it checked out. you were right my friend. apparently these accords are notorious for problems with the main relays. better than an expensive fuel pump.
93FlatBlackHatch
Dec 30, 2006 03:22 PM
