code 21 vtec solenoid
just put my old gsr motor into a new shell, only cel left is 21 (vtec solenoid malfunction). The shell is a 95 Special Edition. I got a gsr dash harness and new engine harness for it, installed them, everything works, only cel is 21.
These are the things ive done to work with it, im sure its going to be a simple fix, im just overlooking it and any sugestions would help.
1. Cleaned solenoid screen
2. Swapped another p72
3. Swapped another gsr vtec solenoid
4. checked ground and signal wires
5. Checked oil pressure (idle and under load)
6. reset ecu after every attempt
The solenoid and ecu i swapped to try and fix are both proven to work off of another car i used to drive.
Final twist:
after each part swap and reset, before starting engine and test driving, code 21 is still showing. This leads me to believe (obviously) that it is an electrical problem, not mechanical. Please....Sugestions
Final twist:
RoaringTurtle
18
Aug 5, 2002 01:17 PM
thats what im scared of...i might just run a new wire all the way
