Replacing torque converter, What to go with?
Old Mar 25, 2009 | 04:52 PM
SiR Inspired ED7's Avatar
Default Replacing torque converter, What to go with?
My sisters motor gave out at 300k so I will be getting her a new/used long block and I will be replacing the torque converter since it has alot of miles. What are some reputable torque converter brands that I should go with? Will I be okay with a kragen/napa auto parts torque converter, what are your suggestions?
Old Mar 25, 2009 | 07:43 PM
Default Re: Replacing torque converter, What to go with?
Am I asking in the right forum?
Old Mar 25, 2009 | 07:45 PM
19Accord97's Avatar
Well just remember that the OEM torque converter has lasted 300k miles and so should another oem torque convertor. Sometimes buying house brands can cause more headaches and more $ in the long run. But Napa seems to have better built products but are more costly.
Old Mar 26, 2009 | 05:34 AM
TouringAccord's Avatar
H-T Order of Merit
well, what car is this for? Is it for a 1990-2002 Honda Accord? If so, then yes, you asked in the correct forum.
Old Mar 26, 2009 | 04:56 PM
Ok, I am in the correct place.
Old Mar 26, 2009 | 05:07 PM
technine's Avatar
Are you replacing the tranny too or just the torque converter? From what I can see the torque converter is a pretty strong component and doesn't usually go out, but I guess you would have piece of mind if you did replace it.
I would be more concerned about the transmission, but if all is well with both, I would just put the original back on.
Old Mar 27, 2009 | 02:44 PM
there really hasnt been any probloms with the transmission. Maybe what i will end up doing is pouring out the oil from the torqe converter/tranny and put some new stuff in there, i think that will make a good difference. Any thoughts on this??
Old Mar 27, 2009 | 02:51 PM
technine's Avatar
Well of course that is a good idea, but you're going to have to drain the tranny before you can take out the engine. If you don't you will have a big mess when you take the engine out and when you seperate the transmission from the engine the torque converter is going to spill out tranny fluid so be ready.
Of course, changing the fluid is always a good idea.
Old Mar 27, 2009 | 05:42 PM
Yeah i know that i have to drain the oild before pulling out, THNX for the tip though
Old Mar 29, 2009 | 04:44 PM
Its been giving my sister alot of trouble, It leaks everywhere from rear main seal to oil pan gasket and the rings are shot. So f22b is going in =]
Old Mar 30, 2009 | 03:51 PM
Does anyone know from the top of her head how many quarts of transmission fluid it takes to fill up torque converter/tranny?? i called the dealer and the guy mentioned 6 quartsz but it sounds like it is a little bit to me.
Old Mar 30, 2009 | 05:01 PM
technine's Avatar
I think that is about right. I think it was 2.5 quarts to refill, but 6 quarts to fill from empty/new install. It's been a while, but I believe that is correct (6 quarts).
If you are worried, just keep checking your dip stick for your tranny.
Zudick
Honda CR-V & Element
Apr 20, 2017 06:40 AM
Jmb106jr
Jun 8, 2015 07:38 AM
smxcan
Jan 12, 2009 07:17 PM
743power
May 31, 2004 11:07 PM
