Windshield Banner
Old Mar 25, 2009 | 01:14 PM
JustinJames05's Avatar
New User
Default Windshield Banner
Is there anyone out there in the Pittsburgh area that are good with vinyl decals? It's one thing I'm definitly awful with. I need one removed, and a new one put on. Or if anywhere knows of a business around town I can get one made and put on that would be great, because I'm not too crazy about this new one I ordered online.
Old Mar 25, 2009 | 05:53 PM
19Accord97's Avatar
Default Re: Windshield Banner
You can remove a windshield with some goo gone and a razor and it is easier on a warm day.
When you install your banner, use a dry erase marker and simply mark on the windshield where the halfway point is and any other guiding marks that you need. Then you can wipe it off w/o a problem. Good luck!
Old Mar 25, 2009 | 06:04 PM
New User
Thank you so much! Should I do a wet or dry application? I hear good and bad things about both.
Old Mar 25, 2009 | 06:05 PM
TheMuffinMan's Avatar
He knows where you live!
Apply it like tint would be my guess assuming it's vinyl.
Wet the area thoroughly and squeegee out the water when it's in place.
A heat gun would probably help in the removal too.
Old Mar 25, 2009 | 06:23 PM
Carcrazy1
Guest
Posts: n/a
If you are not well-knowledgeable about the procedure, then you must go to the specialist to handle your simple problem.
Old Mar 25, 2009 | 06:28 PM
New User
Well the way I look at it, you never learn how to do something, even "simple" unless you try it out yourself. Thanks everyone.
Old Mar 25, 2009 | 07:05 PM
If you don't have anything useful to post as you haven't for the other 18 posts you have. You shouldn't post.
I looked, you've posted in practically every TECH section without a single post containing any TECH.
- S2000
- 90-02 Accord
- 03+ Accord
- RSX/EP3
- Integra
etc
Old Mar 25, 2009 | 07:20 PM
19Accord97's Avatar
It is not hard really. Most places charge nearly $50 or more the make a windshield banner and even more to install it. All you need is a friend or two. I installed me Accord windshield banner with my dad and it came out just fine.
If it is vinyl you dont need water. Simply clean the area with dish soap and water, let it dry, and apply the banner. To apply a decal banner the banner has a sheet of paper over it and a paper backing. Remove the backing, stick to windshield, use a credit card and firmly press all of the decal to remove all air bubbles a few times and then slowly remove the top layer.
Be warned though, that in most cases, you cannot stick the decal and then lift it back up or it will be ruined. Also make sure there are no crinkels. When I did mine, I made sure it was centered and then taped the top of the decal to the windshield, flipped up the decal, removed backing and then evenly flipped it back down.
Old Mar 25, 2009 | 08:05 PM
notAdiesel's Avatar
i did the same thing that 19Accord97 did when i put my decals on my truck. they weren't as big as a windshield one, but just watch out because once it's on the glass it can't be removed. make sure you clean the glass good before you stick it on too
pd0019
Honda Civic (2006 - 2015)
Sep 25, 2007 09:55 PM
HaiSpeedRacer
Oct 5, 2005 11:30 PM
Sephro
Jan 28, 2003 10:23 AM
TsunamiZC
Sep 10, 2002 11:11 AM
