Fuses - Broken but not blown?
Well i Finally got back up and running!
I replaced the battery & ignition fuses THE WERE NOT BROKEN but i guessed, can't hurt - and it solved the problem!!!
IDK how but can fuses just wear our and not break???
Thanks for all the help here on HT if it wasn't for you guy telling me to check them over and over i would have never tried!
Just because a fuse appears to be ok doesn't mean it is. Always check them with a meter. Check the resistance (Ohms setting on the meter) and if they read OL, they are bad
does anyone know what the resistance should be when testing with an ohm meter? i know it will vary depending on the amperage rating on the fuse, and probably the volts going through it (even though there won't be any when testing). i learned something about this in physics last year but i forget it
can you cut it instead, it might be better that way. i would try a couple other places to see if you can get the correct fit before doing that though just to see if they have the right one
you have stressed the new one. you should try and find one that fits better. Trimming it is a good suggestion.
A good fuse should show close to 0 ohms resistance when you test it. There will be a very small voltage going through it when you test it.
You don't need to pull them out. They have two little slits on the back side of the fuse that you can use to check them while still in the holder
HotImportNightHonda
14
Oct 10, 2024 12:34 PM
superchi
Oct 26, 2008 03:49 PM
