can i use stock ecu on low compression pistons
Old Mar 25, 2009 | 07:17 AM
hondacura22's Avatar
Icon6 can i use stock ecu on low compression pistons
i have a 92 integra ls i am going turbo but i want to run no turbo for 6 months can i use stock ecu and fuel system on low compression pistons ? will i hurt my motor without a tune?
will it run to rich ? or am i in the clear i am using wiseco 8.5-1 pistons
Old Mar 25, 2009 | 07:23 AM
RedMenDC2's Avatar
Default Re: can i use stock ecu on low compression pistons
Low compression...well it shouldn't hurt at all! But the like you said...it will run rich. If your not going to run turbo for the next 6 months. Put back on the high compression pistons. That way your ls wont lag!!!
Old Mar 25, 2009 | 04:54 PM
Scheizty's Avatar
your motor is going to hate you outside of closed loop. When your engine wants to richen the mixture at high rpms, you are going to wash out your rings. Use that ecu to get the car running in the garage, but you are only doing your engine damage when it leaves the garage. Save your money and put the pistons in when you get the turbo. Even if you do get a tune, you are making less hp without boost. Why would you want to put miles on pistons to make less power than the ones you have?
Old Mar 25, 2009 | 06:05 PM
berb_15's Avatar
I was in a situation where i installed my motor but had to drive the car because it was my only one so i lowered the compression and drove it for almost a year, but my compression was only lowered 0.2:1 so it wasn't that much of a difference, 0.7:1 is a little larger drop, not sure how it would run.
Old Mar 25, 2009 | 06:07 PM
berb_15's Avatar
hondacura22 you could always just get a street tune on uberdata or chrome untill you get your turbo setup installed
redDAinteg
Jun 19, 2005 05:58 PM
legoman
Jan 25, 2005 01:49 PM
ACrite3404
Apr 15, 2004 03:07 PM
ahc'monracing
Jun 18, 2003 02:05 PM
baonest
Apr 28, 2002 04:51 PM
