evap system removal - BB6 chassis
Old Mar 23, 2009 | 11:21 AM
Scheizty's Avatar
Default evap system removal - BB6 chassis
I want to remove the evap system from my 99 prelude. She is running an s300 hondata so I am not worried about codes. My concern is the gas tank ventilation. I don't want to vent gas vapors into my engine bay or lose most of my fuel to the atmosphere. For those out there that have removed the evap, how did you solve the problem? Should I just plug is and use a vented gas cap?
Old Mar 25, 2009 | 04:48 PM
Scheizty's Avatar
Default Re: evap system removal - BB6 chassis
bump. I know I'm not the only one that has removed an evap system.
Old Mar 25, 2009 | 05:26 PM
shawn69's Avatar
I've just run the ventilation open to the atmosphere in my engine bay. I'm not concerned about loosing my gas as vapor, i have no proof, but i doubt you loose too much. Probably wouldn't even notice the difference. I don't even thing you will get any codes, but not 100%. I didn't with obd0.
Just run the line to the ground, unless your concerned with the environment or something. Avoid exhaust.
Old Mar 25, 2009 | 06:39 PM
96 GSR-T's Avatar
I just left my line in the bay open too, I am unaware of any issues in doing so.
Old Mar 25, 2009 | 06:52 PM
srmofo's Avatar
obd2 would throw a code but he has hondata so no issue anyways....just bend the line downward out of the bay if your concerned
a267mm
Apr 23, 2012 11:04 AM
EKHWhat
Feb 24, 2007 05:02 AM
clemsoncb7
Jun 7, 2005 03:35 AM
3gLudeH22A
Jan 26, 2003 01:36 AM
