b16 Engine coolant temperature Help
Old Mar 25, 2009 | 03:50 AM
dtddemon's Avatar
Default b16 Engine coolant temperature Help
hi guys im new to these boards and it looks like theres alot of help here. so here goes, ok the car is not ever heating, i replaces the radiator fan switch (the one that goes in the thermostat housing) and i replaced the coolant temp sensor which is in the side of the head and im still getting the code the light is blinking 6 times in a row and then stops and does it all over again.
thanks for any help in advance
Old Mar 25, 2009 | 03:53 AM
BryanM.'s Avatar
Resident Gearhead
Default Re: b16 Engine coolant temperature Help
Try reseting the ECU by disconnecting the battery for a few seconds, then see if the CEL comes back on.
Old Mar 25, 2009 | 04:01 AM
dtddemon's Avatar
thanks for the reply i tried that and i ran the car, refilled the water that leaked out all the bubbles out of the radiator, i disconnected the batter for an hour or more, while i went to sleep and took out the backup fuse also. i also tried unplugging the ecu as well, and im still getting it
Old Mar 25, 2009 | 04:08 AM
laziebun's Avatar
what does the code say? beside 6 times? i never heard of a cel for temp problem, or i could be just out of it. I would try this, take the single wire that goes to the temp sending unit in your head and ground it. Turn on the car and see if the temp guage moves up. Do not let it sit there you have to be some what quick on the draw so you dont **** up the guage.
Old Mar 25, 2009 | 04:13 AM
dtddemon's Avatar
thats the weird thing about it, my gauge reads fine it goes from cold when starting up the car to almost the middle when the car is hot, the fans turn on no other codes are thrown only that one also forgot to mention this is a b18c1 block with a b16 head and a chipped p28 ecu to run as a gsr
never had any codes before but i recently took out the engine to replace all gaskets and seals because it was leaking oil and i wanted to check all the internals and all are fine but im stuck with this light for now
Old Mar 25, 2009 | 04:25 AM
laziebun's Avatar
Here you go see if will help you out....
Old Mar 25, 2009 | 04:28 AM
laziebun's Avatar
damn you cant read that....what your email ill send it to you
But it sounds like your ECT sensor
Old Mar 25, 2009 | 04:29 AM
laziebun's Avatar
Have you check the ECT sensor? or do you have a good one off a buddy you can try?
Old Mar 25, 2009 | 04:45 AM
dtddemon's Avatar
thanks for the pics dude i had crossed the vtec pressure switch plug with the coolant sensor i spend 60 bucks in sensors when mines were good but car is running good now thanks :D for the help vtec is running and hitting strong now
Old Mar 25, 2009 | 04:54 AM
stagen's Avatar
Haha thats great... only because I just did the exact same thing acouple weeks ago after dropping in my rebuilt motor. :p
Old Mar 25, 2009 | 04:56 AM
laziebun's Avatar
Very well my little grass hopper! But im glad you get that solved.
Old Mar 25, 2009 | 04:57 AM
laziebun's Avatar
your temp sensor in your head is good? well i need one sell it to me
Old Mar 25, 2009 | 05:16 AM
dtddemon's Avatar
yea its good lol the car never over heated and i test it with a volt meter. where u stay at pm it and we can talk about it if u have a msgr that would also be great :D
h0nda n00b
Apr 25, 2012 09:24 AM
eghatchfla
May 31, 2010 07:17 PM
jadugartir
Aug 4, 2005 12:15 PM
Project_ED8
24
Nov 22, 2003 12:16 AM
