Swaybar material?
Old Mar 24, 2009 | 08:58 PM
55superbeetle's Avatar
Default Swaybar material?
I want to bend up a simple swaybar for my car. Im assuming they are made out of some sort of spring steel. Do you guys know where I could get the material? Looking for something in the 3/4 inch range but would like a few different sizes so I can experiment.
Thanks
Old Mar 25, 2009 | 07:25 AM
CRMB's Avatar
OG Fabricator
Default Re: Swaybar material?
Swaybars are made from normalized 4130 chromoly solid bar. It's not something that can be bent DIY.
Old Mar 25, 2009 | 07:38 AM
4cefed's Avatar
do a splined sway bar, it would work better and be easier to DIY
Old Mar 25, 2009 | 07:57 AM
DESTROYER's Avatar
/\TROO STORIE!
Take a look at these:
http://www.1speedway.com/608_175bars.htm
http://www.circletrack.com/howto/ctr...bar/index.html
Old Mar 25, 2009 | 09:37 AM
Karl Buchka's Avatar
If you want to get real baller you should install a splined bar with knifed sway bar arms.
http://www.ofiengineering.se/Car/Kra...hammareBak.htm
Rotate the arms to adjust the rate.
Old Mar 25, 2009 | 12:26 PM
DESTROYER's Avatar
Can you explain whats going on in those pictures?
Old Mar 25, 2009 | 12:42 PM
TunerN00b's Avatar
The yellow blade is rotated to change the stiffness of the bar.
When the blades are vertical, they're very stiff. When horizontal, they flex in addition to the bar, reducing the total rate.
Old Mar 25, 2009 | 03:20 PM
89civicdx's Avatar
hi check this out
http://forums.pelicanparts.com/showthread.php?t=210077
Old Mar 25, 2009 | 05:51 PM
DESTROYER's Avatar
Excellent link! Thanks!
edit: Good Pic.
http://forums.pelicanparts.com/uploa...1110444949.jpg
Old Mar 25, 2009 | 06:23 PM
toyomatt84's Avatar
Sanji
Another source for a decent anti-sway bar:
http://www.hrpworld.com/index.cfm?tp...action=product
Old Mar 28, 2009 | 07:28 AM
shortyz21's Avatar
those are really cool.
Old Mar 28, 2009 | 09:55 AM
HiProfile's Avatar
You could get a rod of spring steel, then make one similar to a spined version. The cheap way to do it would be the grind the ends flat, so you can clamp arms on like its a flat bar. The arms would just need to be slotted, slid on, and bolted tight. Just beware that grinding and welding spring steel can change it's 'spring' properties.
Mcmaster.com sells lots of alloys (so will your local steel place), although I'm not really sure what to use. The stuff other sites say is good spring steel (W1, 1045, etc) would be under $20 for a 3/4"x36" rod. I think the splined versions with stiff arms would end up stiffer than a normal bar, since the ends don't bend like normal bent-bar sways.
Old Mar 31, 2009 | 06:15 PM
89civicdx's Avatar
hi heres another pretty cool bar build
http://www.blackout.nu/TECH/REAR_END_ANTI_ROLL_BAR.htm
Old Apr 1, 2009 | 09:44 AM
jweller's Avatar
there's a lot of nice fab going on throughout that build. wish I knew enough of whatever Scandinavian language that was to understand what was going on.
Old Apr 2, 2009 | 07:45 AM
http://translate.google.com/translat...hl=en&ie=UTF-8
That should let you at least get a rudimentary idea of what's going on. If there's anything specific you want translated let me know.
jdm_special
23
May 19, 2018 07:35 PM
NovaRex
May 23, 2016 07:17 AM
Fnix
Suspension & Brakes
Dec 31, 2010 02:37 PM
tweek_boii
19
Nov 13, 2009 06:31 AM
TegoDC5
Suspension & Brakes
14
Sep 13, 2005 08:45 AM
