D15b8 into vx O2 sensor CEL issue
Old Mar 24, 2009 | 10:37 AM
prjct92eh2's Avatar
Default D15b8 into vx O2 sensor CEL issue
I swapped the D15b8 out of my 92 CX into my 92 VX. The engine ran perfect before, no CEL or anything. Now that it is in the VX i am getting an oxygen sensor CEL. I have the CX engine harness plugged into the VX chassis harness (minus the wide band O2 sensor plug) and using the CX ECU. After researching wiring diagrams and seeing the below picture i swapped the wire shown in the pic since the 4 wire and 1 wire O2 sensors use the same signal wire circuit.
However i am still getting the CEL. While i understand that it is totally possible the O2 sensor could have gone bad while swapping the engine i'd like to rule out all possibilities before springing $80 on a new oxygen sensor. The CEL doesn't come on until the engine is fully warmed up and driven some. For example, i started the car and left work yesterday and went 14 miles before it came on. I'm assuming it happens when the ECU goes from closed loop to open loop. Some thoughts i've had:
1) The VX i swapped the engine into had what i'm sure is pretty old gas in it. Can bad/old gas ruin an oxygen sensor?
2) Is there still a wiring issue i'm missing?
3) Can i put a known good 4 wire O2 sensor on the engine and connect the signal (white) wire to the engine harness and test that way?
4) ???????
Just trying to see if anybody else has some thoughts. Thanks in advance!
Old Mar 25, 2009 | 09:17 AM
prjct92eh2's Avatar
Default Re: D15b8 into vx O2 sensor CEL issue
nobody has any thoughts?
Old May 4, 2022 | 11:24 AM
92yengcha's Avatar
I know super old thread but did you find any answers to this issue
DALE-EK4
40
May 3, 2007 11:41 AM
FBPninetynineEM1
Nov 17, 2003 04:25 AM
GReddy SI
11
Mar 17, 2003 07:19 PM
unstopabledj
Nov 20, 2002 05:02 PM
92CIVICCX
Jul 30, 2002 10:51 AM
