d16 to around 160 hp?
hello everyone
i want some help from you guys about my conflict
i want more power from my stock d16z6 motor but i dont want to go crazy for now with turbo's and all that..
i want my engine to go around 160 hp without to open the engine for pistons and all that..
what do you guys sugesst me to do?
thanks
adi
thanks
adi
What do you mean not a problem? the OP stated that he doesn't want to open the engine to replace anything (pistons, valve train ect.) You WILL NOT achieve 160hp without opening the engine up and increasing compression to at least 11.5:1 and getting some aftermarket valve train.
^^ Yeah but to port the head you have to take the engine to bits anyway. And there is hours of work in a decent P&P.
If I were you i'd just save my pennys, stop pissing around and do an H-swap, its a weekends work even for a pie-fingers. Just use Yonaka mounts nice and cheap and bulletproof.
I don't get it you want 160 whp and u don't want nos or a turbo...and u don't want to build the engine and if you don't do anything I just posted ur proly only see 140 with bolt ons and lil ****
Face it buddy, your gonna have to suck it up and crack open your engine. I hate to say it, but the D16 just doesn't generate enough power to get what you want. Do the bolt-ons first if you like, but to reach your 160 goal you'll definitely need to do more.
If I can get 160+ from a 1.5 with minimum add ons. Then I am sure it is very possible. But you will need to at least pull the head off.
1.5L non vtec
stock rods & rod bolts
p29 pistons which only give me about 11:1 compression
stock head with fresh valve job & milled .040
Bisimoto camshaft
Dual 45mm Weber carbs
Garbage header
Thats all......
This season I am building another d15 but with 76mm 15:1 compression and porting the head. Pretty much everything else will be the same
Bisimoto camshaft
Garbage header
Thats all......
and what about cold air intake like v2 or something with 4-2-1 headers with 2'' pipe all the way with free flow rear box?
will i get something from this?
what bolt ons can i get fo starting?
xKAMILxEK
10
Aug 21, 2009 01:35 PM
jawsiiv
Mar 20, 2008 07:33 PM
