Are my bearings toast?
Old Mar 23, 2009 | 09:31 PM
2004es2's Avatar
Default Are my bearings toast?
So I just got home and turned off the radio and noticed that there was a clicking noise coming from under the hood. I popped the hood and reved it a bit from the tb and the noise seems to be coming from the block right under the distributer. The motor is a d16y8 turbo but I didn't take it past 6500 rpm so I don't know why it would start doing this all of a sudden. Can anything else be causing this clicking noise. Its not that loud so I'm not certain.
Old Mar 23, 2009 | 09:38 PM
Warhawk's Avatar
Default Re: Are my bearings toast?
is it tuned?
if it's not how long did you drive around untuned?
Old Mar 23, 2009 | 09:50 PM
2004es2's Avatar
I got a chip for it and it ran good, like stock, and I just got the turbo in a couple days ago. I really didn't get on it though. I was planning to get a tune sometime next month but if its bad then I might as well rebuild the bottom end if it will be disassembled.
Old Mar 23, 2009 | 10:09 PM
Unseen Racer's Avatar
its only clicking? not tapping?
cuz if its tapping then you have a spun rod bearing or spun main bearing
Old Mar 23, 2009 | 10:30 PM
2004es2's Avatar
Its a sligh click barely noticable at idle but gets a bit louder at around 3k rpm. Could it be a problem with the head because that would be good news since i was going to rebuild it shortly.
Old Mar 23, 2009 | 10:35 PM
try posting a video so we can hear this click.
Old Mar 23, 2009 | 10:44 PM
2004es2's Avatar
Will do. Ill get it up tom.
Old Mar 23, 2009 | 11:25 PM
kls023's Avatar
From: Your house, your mom's house, your dog's house... basically anywhere you've been! haha
Maybe valves?
Old Mar 24, 2009 | 08:41 AM
rickkane's Avatar
Could it be a noisy throwout bearing or pilot bearing, since the trans is right there too. I had some funky noises coming from my old trans that are gone now with a new tb and pilot bearing. Just a thought.
Old Mar 24, 2009 | 09:01 AM
superbean's Avatar
could even be an exhaust leak. IF you went turbo, im sure you got some different exhaust tubing that may have loosened up.
you would know if it was a rod or crank bearing, trust me lol
Old Mar 24, 2009 | 09:16 AM
seth95integ's Avatar
Open up your distributer cap, the rotor bolt mit come off. Happens to me and it's an easy one to check first.
Old Mar 24, 2009 | 05:21 PM
2004es2's Avatar
I tried posting a vid but it didn't load so I might try putting it on youtube and putting up a link. If it is the bearings, how much would it be to have a shop install low comp. pistons and h beam rods and polish the crank and new bearings? This one shop quoted me 1300 for labor but that seems crazy high for just labor.
Old Mar 24, 2009 | 08:21 PM
Warhawk's Avatar
In for updates, you get the video to work?
anyway, if it was a rod bearing it would be kind of inconsistent sounding.
for example, if you had rod knock you would hear the knock sound maybe every other engine cycle and and no particular pattern.
A noisy head will make a consistent "tick tick tick tick" on every engine cycle. Here is a pretty good example of a noisy head..
http://www.youtube.com/watch?v=JOmBb...eature=related
Old Mar 24, 2009 | 08:32 PM
sounds nasty
Old Mar 25, 2009 | 08:35 PM
2004es2's Avatar
It sounds exactly like that but not as loud. So what was the problem with that motor?
LOL n/m, valve knocking. I just saw it.
Old Mar 25, 2009 | 09:16 PM
2004es2's Avatar
Heres the vid. You will notice that only when the camera is close to the motor it is loud.
http://www.youtube.com/watch?v=0-g_LIpHFM4
Old Mar 25, 2009 | 09:24 PM
Ran4it2's Avatar
sounds like it needs a valve adjustment
or a rod knock.
Old Mar 26, 2009 | 11:31 AM
2004es2's Avatar
Ok. Ill try the valve adjustment first. Anyone know the crearace specs?
Old Mar 26, 2009 | 08:01 PM
2004es2's Avatar
I just did the valve adjustment and it is still making the same noise. I am guessing its the block. Not good.
Old Mar 26, 2009 | 09:06 PM
r34killer's Avatar
New User
its a spun main bearing. because you didnt tune the car when you got the turbo it just got worse and worse over time. even with a small ammount of boost, it spun the beading the second u turned on that car. it may not have spun it much but enough to thro it off and it finally got bad enough for you to hear if and notice. do you know how your oil pressure is?
Old Mar 26, 2009 | 09:19 PM
Warhawk's Avatar
hmm, kind of hard to tell. It has the pattern of a noisy head but sounds like a rod. Do you notice any noticeable loss in power on high end? Clean *** bay by the way!! HD ftw!!
Old Mar 27, 2009 | 02:08 AM
2004es2's Avatar
Yeah thanks. Well it happened when i was coming home and I didnt feel any power loss. I didn't notice until i got home that it was ticking.
peakboosth22
Apr 1, 2007 01:25 PM
SupaFly_Honda
Mar 1, 2007 12:48 PM
petergriffen
Feb 25, 2007 05:15 PM
Touge Tuning
Jul 4, 2006 09:13 AM
