lack of power
Old Mar 23, 2009 | 12:33 PM
delslow302's Avatar
Default lack of power
when i hit vtec my car loses power
Old Mar 23, 2009 | 12:36 PM
dividedas1's Avatar
Default Re: lack of power
any cel's?
are you sure you are even getting vtec?
Old Mar 24, 2009 | 04:11 PM
papito_85's Avatar
bump cause i have the same problem
Old Mar 24, 2009 | 04:58 PM
makin1meand's Avatar
timming
Old Mar 24, 2009 | 05:01 PM
cmc600rr's Avatar
timming?
Old Mar 24, 2009 | 06:35 PM
delslow302's Avatar
i tested it again to day when i first take off eveything is fine it hits vtec through evey gear then when i slow down and try again it doesnt work.... and timming is on piont
Old Mar 24, 2009 | 06:42 PM
93egSLEEPER's Avatar
what rpm is you vtec kicking at? what motor?
Old Mar 25, 2009 | 06:50 AM
delslow302's Avatar
yeah man got plenty of vtec fluid... i may not know everything yet but im not a dumb ***
its a d16a6 with a z6 head... vtec kicks in around 5k or so
Old Mar 25, 2009 | 02:03 PM
delslow302's Avatar
i fixed it........ it was the turbo button!
Old Mar 25, 2009 | 03:04 PM
Originally Posted by delslow302
i fixed it........ It was the turbo button!
wtf?
Old Mar 25, 2009 | 03:10 PM
GSR-EG-92's Avatar
1. You need to set the small VTEC solenoid timing chain correctly
2. Your VTEC isnt spooling up to redline
3. Your low on VTEC fuel, I use only 110 octane in my VTEC fuel tank
Old Mar 25, 2009 | 05:50 PM
GSR-EG-92's Avatar
By the way OP, Im not trying to be a dick with my last post, just having a little fun. You got the problem sorted on your own, good work.
Old Mar 25, 2009 | 05:51 PM
nbcivic's Avatar
isn't vtec hardly noticeable to begin with on single cam
Old Mar 25, 2009 | 06:04 PM
GSR-EG-92's Avatar
You can hear vtec on a single pretty well but as for power I dont know.
Old Mar 27, 2009 | 06:09 PM
delslow302's Avatar
im a dumb *** and i forgot i had bigger injectors in it so its was getting flooded... kind of
touintegra1
Aug 13, 2023 08:28 PM
Anythingbtcivic
Oct 21, 2017 11:53 PM
aziz93
Sep 6, 2004 10:05 AM
-iLLuZioN-B18C1
Jun 14, 2003 01:48 PM
crx(gator)
14
Feb 12, 2002 06:04 AM
